So I've searched a bit regarding this issue with the drop target underneath the borg ship, but no one seems to have the same issue. The target was getting stuck in the down position. The leaf switch was getting stuck on top of the mechanism that pushed it down. So I adjusted it physically and tilted the switch to a slightly different position. Testing the drop up/down works just fine, no issue at all. The real issue now is the target appears and sounds like it's trying to reset over and over when a drop target mode is activated. It should drop when, for instance, launch probe mode is activated. It does sometimes but not every time. Then again, sounds like it's resetting over and over. Any direction would be great. Thanks
