I had one random reset in the middle of a game the other day, and now I can replicate it 100% of the time. It *ONLY* happens when I hit both flipper buttons simulatenously. When a flipper is hit individually, there's the slightest of luminance drop on the playfield lights, but I've noticed that on plenty of other pins.
I looked under the hood and noticed that the right primary flipper coil only had 1 diode on it (between the blue/violet and blue/yellow wired lugs -- common and large winding). I was like bazinga, and went ahead and the lone diode and added two new ones. No change. Wall voltage is a generous 121VAC.
I'm going to begin the journey through the PinWiki reset section, but I was wondering if there was something my symptom points toward. I have not had nor can produce a reset any other way. I was for sure the lack of a diode would have caused it, although I suppose it should have tripped that problem earlier.
