Hi,
I have a favor to ask. Can someone who has an STTNG tell me what the maximum width is? Google yields a "pins of that era" answer and I know one of you guys will know. Thanks!
-S
Quoted from swf127:Hi,
-S
The head is the exact same width of your other pins... Should be 28 inches. The "Coffin" part of the playfield is a bit wider (about 2 "). Also note the machine is heavier than normal (about 350 pounds instead of 250). Can try and get you exact measurements tonight if no one else answers. If you took a fish tales, World Cup Soccer, or Attack From Mars out of a lineup, this would fit in the exact same spot (Backbox part), but the legs would be a few more inches apart.
Quoted from SantaEatsCheese:The head is the exact same width of your other pins... Should be 28 inches. The "Coffin" part of the playfield is a bit wider (about 2 "). Also note the machine is heavier than normal (about 350 pounds instead of 250). Can try and get you exact measurements tonight if no one else answers. If you took a fish tales, World Cup Soccer, or Attack From Mars out of a lineup, this would fit in the exact same spot (Backbox part), but the legs would be a few more inches apart.
Thanks. If you have a minute to put a tape measure to yours this eve that would be great. I know it's going to be a tight fit. I remembered they're heavy and full of temperamental optos but such a great pin!
Quoted from pinlink:Right under 29”
Thanks! Time to see how boned I am.
If clearance is an issue just remove the head…the body is a couple inches narrower. Not a huge deal if it’s a one time move. No need to risk damage to the game and door frame of its that tight. It’s not that difficult to remove a head. Some people make it out to be a big deal when it’s really not. Especially if it’s going to be a long time before you move it again.
Quoted from Pickle:If clearance is an issue just remove the head…the body is a couple inches narrower. Not a huge deal if it’s a one time move. No need to risk damage to the game and door frame of its that tight. It’s not that difficult to remove a head. Some people make it out to be a big deal when it’s really not. Especially if it’s going to be a long time before you move it again.
Thats the plan. I’m just going to label connectors and take a bunch of photos in the process. I’m doing a long distance move and wanted to make sure I had a plan for this guy since there’s this one turn getting into my game room that’s tough. I’m really looking forward to having it back. Thanks!
This page was printed from https://pinside.com/pinball/forum/topic/sttng-dimensions and we tried optimising it for printing. Some page elements may have been deliberately hidden.
