When booting up the game I'm having issues with the right cannon firing, the plunger staying out, and the cannon never stops rotating. I barely touch the plunger and it will go back in but then fire and stay out again right after. From reading other posts about sttng cannon issues the first thing often recommended is to replace the wiring harness. So I purchased 2 replacements from the Pinball Wizard (http://www.thepinballwizard.net/index.php?p=product&id=1822) and I figured out where the wires go etc. I've pulled the cannon off the machine and looked it over several times and don't see where there is a diode to be replaced. So my question is where does the diode go? Thanks for the help.
