I've been helping someone out with an AFM off and on.
The only thing not working on the game right now is the strobe.
First, I replaced the caps. The strobe flashed twice and that was it.
I verified that there is continuity for the wiring from the strobe PCB to the driver board PCB. Voltage to the board appears to be good.
Then I replaced strobe tube, trigger, U1, and Q1. All the diodes tested good (and were oriented correctly), and I replaced D7 just in case. However, the strobe still does not flash.
Are there any other common points of failure?
