I know everyone likes to do things the way they like to do things, so this thread is not intended to be a tutorial on how you should do anything, rather, it is one way to do one job in a way that has worked extremely well for many years.
You always hear "use toothpicks" or "use skewers". I suppose both will work but I have found toothpick wood either too soft or too brittle, depending. Anyway I'm not trying to start a debate on which is better. This is just how I do it, and documenting the process might help a few beginners.
The first step to repairing a stripped screw or post hole, is finding a stripped hole. There's one now...
I guess I'll need some stuff to plug that thing up.
The hole had another one behind it that didn't look too good, so I pulled the post from the other side to see what was what. Turns out the other hole is for conservative/liberal adjustment. I'm leaving it conservative.
The hole is slightly smaller than my skewer, but that's OK, I don't use them whole anyway.
Cut a length of skewer slightly shorter than the playfield thickness. We don't want it protruding up out of the hole.
Once you have your measurement, CAREFULLY score around the skewer.
Flex the scored end back and forth in the directions of the compass. This will prevent strips from peeling down the skewer.
Now use the blade to CAREFULLY split the plug down the middle, then split those halves down the middle and maybe cut another length and split that one several times.
More to come...
