Stern flipper pawl screws on Spike 2 machines. These screws are garbage. Trying to adjust my flippers and all the screws are stripped now. What is a good replacement screw and how do I remove the stripped screws? F'n garbage.
Quoted from JethroP:What stripped? The head or the threads? Is the head allen wrench or hex head?
The head is stripped. Allen. I am reading some old threads that say vice grips will work? As tight as these bastards are I'd be surprised if they worked.
Make sure that your alan wrench is in solid or it will strip. I also use a nut driver for leverage on sterns from factory tight. I learned the hard way too
Quoted from Jaytech10:Make sure that your alan wrench is in solid or it will strip. I also use a nut driver for leverage on sterns from factory tight. I learned the hard way too
Recommendation on what to do once it's stripped? Or replacements screws?
Rubber band or something thinner like latex in head and attempt to turn, Screw extractor, sometimes you can make a notch with a dremel or just drill it out.
Quoted from Shoot_Again:Rubber band or something thinner like latex in head and attempt to turn, Screw extractor, sometimes you can make a notch with a dremel or just drill it out.
This works great if you have the space to get a Dremel in there. Use the cut off wheel and make a notch across the head where you can then use a flathead screwdriver to remove. I’ve had to do this a couple of times in different situations and it always works out well.
The part is unidirectional, you may have it installed upside down.
We are talking about the screw that grabs the flipper right? on the rectangular metal bar. It’s a crank arm block.
When you insert the screw, the side facing you where the screw enters does not have threads. The other side has threads.
if it is backwards it will never tighten around the flipper and you strip the Allen head.
78E546A2-986B-4DEC-AA54-752366EAB136 (resized).jpegFor replacements I got black alloy steel screws at a local Ace Hardware.
You could also go fancy and look into the Precision Pinball keyed shaft / crank bar setup.
This page was printed from https://pinside.com/pinball/forum/topic/stripped-flipper-pawl-screws and we tried optimising it for printing. Some page elements may have been deliberately hidden.
