The machine you described in working condition is worth about $650. Since the rectifier board is not working, there are 2 options when determining value. If you have the means to show up with a working rectifier board (and transformer assembly), it would definitely help you. Without a working rectifier board, it is kind of like buying a used car with a dead battery. Since you can't start the car, you don't know if the engine or transmission work. If you have a working rectifier board, you should be able to see if the MPU is going to boot. If all you needed is a new rectifier board, I would deduct $100 from the estimated value. However, if you don't have a working rectifier board to test in the machine, you run the risk of the MPU, SDB, and displays not working. In this case, the machine is worth about $200.
