Hi
During the solenoid test it will usually make it through the whole sequence once or twice before blowing the fuse, firing each coil at least once.
I'm using a 1 amp slo blo fuse, the sticker was missing, and I couldn't see on IPDB, so I'm guessing on the fuse. Most others used the 1 amp, is this machine different?
All the coils test at 11 to 12 ohms.
I put in a regular 2 amp fuse and it doesn't blow after cycling through the test multiple times.
Any help is appreciated. thanks.
