(Topic ID: 182631)
Street Fighter keeps blowing F25
By waffen_spain
7 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by ImNotNorm
#1 7 years ago
Hi guys, need your help here, hope you can see what I can't
Both ramps are not working cos the Fuse 25 keeps blowing.
If I put a new fuse, everything works fine for a time, can be 2 days, can be a weeks, but finally fuse dies.
I little history about machine problems:
* F25 was overfused, heavily overfused.
* Burnt Auxboard (replaced transistors, fixed damaged tracks)
* Burnt left ramp coil (replaced the coil with an original old stock)
* Q8 Transistor burnt (left ramp), replaced and verified to work.
* Left ramp coil EOS switch checked and adjusted, its broken 500V ceramic cap replaced (broken leg)
As you see most of the parts related to the left ramp are new (coil, eos capacitor and q8 transistor), during game the coil gets hot cos as you know it keeps the ramp up, so its energized for a long time, the other ramp coil gets hot too, but no problems.
The old owner put a very big fuse, so the problem is not new (and it also killed the Q8 and the coil for sure).
The melted coil and blown Q8 tells me that the coil is getting too much volts, but the EOS is clean and looks correct, the 500V ceramic capacitor at the EOS has one leg broken so I put a new one, not sure if that cap can be the problem or if its there only to avoid sparks.
What do you think? we really love this game, we play like 20 games everyday trying to beat other friends records
#2 7 years ago
Guys? any ideas? should I replace the EOS switch or check the driver board again? don't know what should be my next step
#3 7 years ago
Are you certain the coil you replaced was wired correctly before? Did you compare it's wiring to any schematic you may have? I have read multiple treads on here about coils heating up and/or blowing fuses etc where one installed a new coil and simply matched the existing wiring on the bad coil only to have the problem persist. I'm guilty of this too, I now double check against schematics the connections as they SHOULD be!
#4 7 years ago
Quoted from Atari_Daze:
HS! I never thought about that!
I did just what you said, replaced the burnt coil and matched the existing wiring
I will check it tomorrow, thanks Daze
#5 7 years ago
Hey - are you still having the issue? Any chance it was the coil wiring? (could you take a picture of the left and right?).
I've had my SF2 for almost a year now and have consistently had the exact same behavior with F25. I did the EOS adjustments, didn't note any loose wiring, and also did replace the ramp coils with the higher hold resistance recommended coils from Steve Young. Even still it's the same as you said - every few days/weeks that fuse is popping.
I didn't have the overfusing or mosfet issues (HUO since 1997 - found the bill of sale in the cab even), but am really trying to remedy this as it's the only thing keeping this from being completely shopped/fixed/etc.
Any info would be greatly appreciated. Thanks!
3 months later
#6 6 years ago
Same problem here. Had the F25 fuse replaced weeks ago and then it blew yesterday....Twice!!
Like @statictrance, I would also like to remedy this as it's really the only issue I have from my SF2 being all fixed up!
Any tips/suggestions/updates are appreciated!!
2,000 (Firm)
Marietta, GA
$ 1.00
Pinball Alley
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/street-fighter-keeps-blowing-f25 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
