I'm at my wit's end with this one. The left flipper is weak. Not weak enough to where the game is unplayable, but it will not make it up the Chun Li ramp at all. Only makes it half way up and comes back down. I've replaced the coil, installed a rebuild kit, replaced the flipper switch, replaced the fuse, angled the machine fast and slow, and it's getting 54.14vdc when the button is pressed. It's just too weak. I have done everything possible that I can think of. There must be a compatible replacement coil that's more powerful than the factory A-25959. You can't defeat all the characters if you can't hit the ramp. ANY help would be appreciated. Thanks - Mike.
