Hi guys
I've had this machine a couple of years now and finally got round to fixing a few things, new flipper coil, reflowed some optics and machine is playing well. Although I do have a couple of minor problems.
1. In this game when you hit certain targets and defeat opponents you are given a prize reward each time, these are selected by the flippers, L for 10 million points or R for Car Crush etc, you have 5 seconds to choose and after that time if you select nothing it gives you the default reward, which is always the L option.
Sometimes I am able to select the reward no problem and at other times I can press the flippers and it won't select anything, which leads to me getting the default reward.
This appears to be quite random as in some games it only happens on one or two occasions, or it can happen every time.
I have reset the table to factory settings but that doesn't seem to make any difference.
2. When a ball gets drained the next ball will not be released onto the plunger until I press one of the flippers. This is only during normal gameplay after a ball has drained, multiballs are always loaded as they should.
Really appreciate any help.
Adam
