Both the left and right ramps should raise and lower. If that's not happening there is an issue. Both of the ramps use fuse F25, so if neither of them work I would start with checking the fuse. Can you lift the left ramp manually, is it seized? Solenoid 7 runs the left stargate ramp, you can try it in the machine's test menu to see if it is working. If it's not working in the test I would check the solenoid to see if a wire is broken or anything else obvious, like the linkage to the ramp is broken. With all that being said if you are shooting the Blanka shot and it is ending up under the left ramp you are missing a piece somewhere because that shouldn't happen.
Good luck.
