I'll try to get to my strato flite today... but for now, my guess is that it's the 10 or 100 pt relay... pulsed by playfield switches - check to see that the switches behind the rubbers are all open, that the kickout at top - that switch under the playfield is also open... also all target switches (those need to be open too).. a lot for you to check, but most likely that's your issue.
Don
Quoted from Dono:I'll try to get to my strato flite today... but for now, my guess is that it's the 10 or 100 pt relay... pulsed by playfield switches - check to see that the switches behind the rubbers are all open, that the kickout at top - that switch under the playfield is also open... also all target switches (those need to be open too).. a lot for you to check, but most likely that's your issue.
Don
It's the 100 point relay - pulsed by the Advance Relay, Eject relay through No. Match Unit, target switches, pop bumper switches... I'd check the target switches on the playfield first, followed by the pop bumper switches that drive the 100 point relay, and then check the advance and eject relays.
This page was printed from https://pinside.com/pinball/forum/topic/strato-flite-score-and-locked-coil-help-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
