(Topic ID: 66694)
Strato-Flite not ejecting ball
By Chum43
10 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 10 years ago by Chum43
#1 10 years ago
So close with this unit... but so far!! This is my first EM and am having a bit of a time reading the schematics. Ball will not eject from out hole which causes score motor to run constantly and bonus stepper steps up then counts back repeatedly as if a ball had just ended. If I trip the out hole manually with no ball it works fine. Eject solenoid seems fine.... clean and loose but there is no voltage ever during the sequence. I have poured over the schematics and cant find the culprit!! Don't see any loose wires anywhere... outhole relay operates fine as well. Any help would be TRULY appreciated!! Schematic is on IPDatabase so I wont bother to post it...
#2 10 years ago
Is the zero position switch on the bonus unit open/closed (whichever it should be, look at the unit as you manually step it down how it should operate) when the unit is fully reset? It won't serve a ball until it is. Also check 4B on the score motor. Is the outhole switch closing when a ball is sat there?
#3 10 years ago
Thanks Nick!! You nailed it. The switch on the bonus unit was operating but sticking up or something. Cleaned it up and adjusted and now she boots the ball out every time!
Thanks again!
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/strato-flite-not-ejecting-ball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
