(Topic ID: 258046)
Stranger Things Club. Join our Party!
By chuckwurt
  • 17,966 posts
  • 778 Pinsiders participating
  • Latest reply 3 days ago by billsfanmd
  • Topic is favorited by 274 Pinsiders
Topic poll
“Which game are you getting?”
  • Pro 187 votes
    40%
  • Premium 148 votes
    32%
  • LE 131 votes
    28%
(466 votes)
21 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 17,966 posts in this topic. You are on page 353 of 360.
#17601 4 months ago
Quoted from Pin_Fandango:
Maybe the licencing conditions changed considering the show is more popular now and so are the people in it.
If they ever do re-run this title it would only be for the pro models.
That's how their last 2 runs of the machine were if I'm remembering correctly. So if you're dead set on the projector just buy the prem or le because those will never be re-run again.
#17602 4 months ago
exactly what everyone that knows better has been saying for years now
#17603 4 months ago
Quoted from SonOfaDiddly:
It was just a guess on my side but makes sense. Thanks
#17604 4 months ago
You can imagine that if the cost to renew the license is so high that there is minimal profit to build them, it makes sense for Stern to focus on other licenses.
It could also be that the license is off the market for any number of licensing, ownership, marketing, likeness, and rights reasons.
It's all reading between the lines on what the issue is.
#17605 4 months ago
Are there any more rumours on another run of this game?
I would hate getting an LE and see then re running an improved special edition.
Is the projector available to buy from Stern?
Anyone looking to buy a projector, this is the best price around - https://littleshopofgames.com/shop/translite-backglass/stranger-things-premium-projector-for-pinball-machine-509-2009-00/
#17606 4 months ago
Anyone ever remove the decal from the center ramp and reuse it? Have a new ramp but no decal and wondering if it’s even possible to get off and reuse. I’ve read a few other posts about doing this but none for Sth. Thanks for any advice! Or better yet anyone have a decal for sale let me know!
#17607 4 months ago
Quoted from pinner11:
Pinball life has projector decals for the premium/LE, but I see you have a pro. Not sure about a building decal.
I guess you need this kit, but none in stock:
https://littleshopofgames.com/shop/decals/decals-playfield-ramp/stranger-things-pro-replacement-decal-set-for-stern-pinball-machine-802-5000-q1/
#17608 4 months ago
I have but it was on a premium. Assuming its the same material thickness...it can be done. Just work slowly and use a hair dryer. Note...I did not because I didn't care. I was using the decal as a template anyway...but it turned out fine, and I stuck it on a sheet of wax paper to use later if I need to.
#17609 4 months ago
Quoted from Soundkillr:
Thanks just installed the lighted translucent drops and used this method to remove the target decals. Worked much better than I expected!!
#17610 3 months ago
**Photo Heavy Post**
Loved this machine since the first time I played it at MGC years ago, knew it was one I wanted to own.
Joined the club months ago, read through the entire club owners thread before it arrived.
Appreciate everyone's advices on adjustments, mods, tweaks, etc...
Finally have it dialed in with all the mods and adjustments I want.
Mods include:
Stern UV Kit
Stern Shaker
Stern Insider Kit - relocated to coin door
Stern Topper
LED Speaker Light Kit (previous owner)
Custom Cup Holders - modfather
Flame effect kit on 2x multiplier, 2x scoring, burn it back - PinMonk
Hot Pink nylon leg bolt washers - PinMonk
Hot Pink Pro Plate Frame - PinMonk
Titan Breeze Fans on flipper coils - PinMonk
Pin Blades (4 color forest) - CoinTaker
Purple LED Flipper Buttons - pinballlife
Drop Target Illumination Kit - MezelModsDesign
Translight Custom Lighting Kit - Lermods
Through Hole Illumination Kit - Lermods
Backboard Illumination Kit - Lermods
Shooter Plate Cover - CoinTaker
Backbox Magnetic Power Splitter - Lermods
Cabinet Power Splitter - pinballlife
External Volume Control - pinballlife
Magnetic LED Hinge Covers - Litedpinballmods
Translucent Plastic protectors - CoinTaker
Friends Don't Lie Button Bezel - CoinTaker
Cliffy Protectors (on backorder) - Cliffy
4 color forest pin blade decals (resized).jpg4 color forest pin blade decals (resized).jpgBackboard LED kit 3 (resized).jpgBackboard LED kit 3 (resized).jpgCustom cup holder 1 (resized).jpgCustom cup holder 1 (resized).jpgDrop Target Illumination BLUE (resized).jpgDrop Target Illumination BLUE (resized).jpgExternal Volume Control (resized).jpgExternal Volume Control (resized).jpgFlame Effect 2x (resized).jpgFlame Effect 2x (resized).jpgFlame Effect 2x Multiplier (resized).jpgFlame Effect 2x Multiplier (resized).jpgFlame Effect Burn it Back (resized).jpgFlame Effect Burn it Back (resized).jpgFriends don't lie bezel button cover (resized).jpgFriends don't lie bezel button cover (resized).jpg
Hot Pink Plate (resized).jpgHot Pink Plate (resized).jpgInsider Connect Relocated (resized).jpgInsider Connect Relocated (resized).jpgInsider Connect Relocated 2 (resized).jpgInsider Connect Relocated 2 (resized).jpgMagnet hinge cover led off (resized).jpgMagnet hinge cover led off (resized).jpgMagnetic hinge cover led on (resized).jpgMagnetic hinge cover led on (resized).jpgMagnetic hinge cover led on 2 (resized).jpgMagnetic hinge cover led on 2 (resized).jpgNew Translite Backboard Lighting 1 (resized).jpgNew Translite Backboard Lighting 1 (resized).jpgNew Translite Backboard Lighting 2 (resized).jpgNew Translite Backboard Lighting 2 (resized).jpgNew Translite Backboard Lighting 3 (resized).jpgNew Translite Backboard Lighting 3 (resized).jpgNylon Leg Bolt Washers (resized).jpgNylon Leg Bolt Washers (resized).jpgPin Monk Titan Breeze Coil Cooling Kit (resized).jpgPin Monk Titan Breeze Coil Cooling Kit (resized).jpgPlastic Protectors left translucent purple (resized).jpgPlastic Protectors left translucent purple (resized).jpgPower Board Add-on Backbox (resized).jpgPower Board Add-on Backbox (resized).jpgPower board add-on Cabinet (resized).jpgPower board add-on Cabinet (resized).jpgThrough Hole LED Kit 2 (resized).jpgThrough Hole LED Kit 2 (resized).jpg
#17611 3 months ago
Long shot but does anyone happen to have a spare right cabinet decal for a pro they are willing to part with?
#17612 3 months ago
Quoted from mooshue:
Gorgeous pin! Whats the purpose of the power splitters? Easier to wire up new mods?
#17613 3 months ago
I just picked up the Stranger Things pro and looking for suggestions on what would be the best UV kit to install or what’s available.
#17614 3 months ago
Quoted from Don44:
Get the official one if you can, pin stadiums are better than nothing though
#17615 3 months ago
When you complete a set of drop targets and it wants you to shoot the center, are the drop target supposed to continuously pop up and down? I don’t remember this happening when I played it in the arcade in the past but is happening on the game I recently acquired. Any thoughts on what’s going on?
Video of what’s happening:
#17616 3 months ago
Quoted from tgarrett09:
When you complete a set of drop targets and it wants you to shoot the center, are the drop target supposed to :
Looks like it might be an issue with the opto. I had a similar issue with the up post and it was because one of the lenses on the opto shattered.
#17617 3 months ago
Nope. Go to the switch test in the diagnostics menu. Start with the drop targets up and knock them down one at a time and see if the 4 switches show their off/on status changing. That is an easy place to start. It may be something as simple as a loose connector.
#17618 3 months ago
Quoted from Gutterghoul:
Yes, exactly that. I've already used the one in the Blackbox for 3 items, 2 in cabinet. Who knows what cool stuff will be out in the future.
#17619 3 months ago
Quoted from Neal_W:
Thanks for confirming I’m not crazy and that’s not part of the game! I didn’t see anything out of the ordinary in switch test or diagnostics, but I messed with the drop target mech a bit and reseated all connectors and it seems to have resolved itself. I’ll keep an eye on it going forward. Thanks!
#17620 3 months ago
The official one does not seem to be available and the pinstadiums are a couple of months out. Does anybody have a kit to sell?
#17621 3 months ago
Quoted from Don44:
Check with flip n out. It won’t be cheap, but maybe they have one.
#17622 3 months ago
Anyone interested in buying the official Stern Stranger Things banner with 5 funko pops (Will, Mike, Lucas, Dustin and Elleven).
I used to have the banner in my pinball room with the funko pop characters displayed above it. I also have the original boxes for the funko pop character’s and they are all in perfect condition.
Need to look up prices and figure out a good price for all of it.
Pm if interested.
I’ll make an official ad soon for it either way.
Here’s a terrible picture I have on My phone for now.
#17623 3 months ago
So I struck out so far with trying to find an official uv kit and not sure I want to spend $500 + on the pinstadium one that seemingly not as good. Is there any cheap hacks to do with uv lights in some of the GI to give some more upside downness? Any chance Stern will make more kits?
#17624 3 months ago
Quoted from Don44:
The UV kit includes plastics with likeness of the actors on them, so they can't make them until they work out a new license deal and it seems the license is currently not available or prohibitively expensive.
#17625 3 months ago
Quoted from Don44:
Is the pin stadium not good? Why?
#17626 3 months ago
Works fine. Just doesn’t behave exactly like the stern kit and obviously doesn’t come with the replacement plastics.
#17627 3 months ago
I have the stern UV kit on mine and don’t think the replacement plastics are that huge of a deal personally. The playfield itself is really the most immersive part so you would be fine with the pinstadium version imo. I think the stern kit would be preferred but definitely get some sort of UV kit on there in general. It’s a huge part of the game for my personal enjoyment of it at least.
#17628 3 months ago
Quoted from chuckwurt:
Why does not it behave the same?
#17629 3 months ago
I have both kits on mine. Had to get the Pinstadiums first due to Stern slacking in making the kits durring COVID.
What is nice is the Pinstadiums helps light up the whole game with the UV.
#17630 3 months ago
Quoted from kidchrisso:
Do they trigger on upside down and else like the oem?
#17631 3 months ago
Because it’s not made and programmed by stern. Pinstadium did not figure out how to make it behave just like the stern kit. Some of the flashing and other lighting effects aren’t there. It’s just on off during upside down mode.
#17632 3 months ago
This sucks.
Not interested on this kit then
#17633 3 months ago
Unless you had the OEM on there for a lot of plays and then suddenly replaced it with the Pinstadium kit, you probably won’t know the difference.
#17634 3 months ago
Is Stern still making the uv kit?
#17635 3 months ago
No. That’s why Pinstadium is now $500 instead of $250.
#17636 3 months ago
And it’s not even programmed right.
Lol junk
#17637 3 months ago
Lol junk
It is programmed as close and Pinstadium could get it.
#17638 3 months ago
Yes, it triggered off one of the lights. I don't remember which one Scott at Pinstadium told me to attach it to. They work great. The Stern ones definitely focus and flash more around the center of the playfield. I like the pinstadiums as you can give just a little extra light to the overall playfield during game play as well.
#17639 3 months ago
My Sth came with the pinstadiums and I would say they are 100% worth it. Are they as good as the official Stern UV kit, I’m not sure having never seen it. But I will say you are missing out if you do not have either as it’s such a great addition to the game. $500 is steep but you also get better/customizable lighting during normal game play which I really enjoy. Having this game without any UV kit is like having kool aid with no sugar or cereal with no milk, just doesn’t make sense.
#17640 3 months ago
the plastics add a lot, too. they're as essential to the package as the lights and PCB are imho
#17641 3 months ago
I wonder if there would be a market for a UV reactive plastic set (or just the slings)
Could be made with generic (non licensed) assets think D20, waffles, vans (this game definitely needs moar vans!)
Have a broken sling plastic on our routed machine and would probably buy a set just to preserve the originals.
#17642 3 months ago
Kool Aid with no sugar! That is one of the best statements on the inter web!
Quoted from pinner11:My Sth came with the pinstadiums and I would say they are 100% worth it. Are they as good as the official Stern UV kit, I’m not sure having never seen it. But I will say you are missing out if you do not have either as it’s such a great addition to the game. $500 is steep but you also get better/customizable lighting during normal game play which I really enjoy. Having this game without any UV kit is like having kool aid with no sugar or cereal with no milk, just doesn’t make sense.
#17643 3 months ago
I could not have my kool aid without sugar so I ordered the pinstadiums. Pinner11 is a good salesman.
#17644 3 months ago
The UV ledstrip are all driven by this board here:
520-8445-00
From what I can see, it's very likely these leds are 12V UV strips, and it's a matter of identifying the pinout of the LED connectors to the board.
Then this board connects directly to the rest of the Spike system, so you instantly get native UV kit control. So with this board and proper wiring you could use the Pinstadium UV kit. Or build your own using cheap Aliexpress UV leds.
At least in theory.
[EDIT] Looking at the manual and available information: this board connects directly to Node 9, through CN14, which is a transistor driven output of node 9. This means it's simply a digitally controlled switch from CN14. This UV led board essentially converts 48V to 12V, and use this digital input to turn on/off the UV ledstrips, you can see on the board picture there are two identical section, one for each side. Frankly, I'm surprised Pinstadium could not figure it out and build a custom board.
#17645 3 months ago
Quoted from Ashram56:
520-8445-00
At least in theory.
Looks like a nice challenge to take on…
I am in
#17646 3 months ago
520-8445-00
At least in theory.
This board is power supply only from what I understand. But maybe it also tells the lights to behave the way they do. Not sure.
#17647 3 months ago
Unlikely. The connection to node 9 is a transistor output, so it's on/off. Also, looking at the board, it's clearly two power sections (you can see the coil, and the voltage regulator is likely beneath the heatsink), there's no additionnal logic, no IC that I can see. I'm willing to bet that if you take a measurement on CN14 pin 5 and 6, you will see it controls directly through the power board the UV ledstrip
#17648 3 months ago
I would like to get this board but the eu store wont ship to North America or anywhere outside Europe it seems.
Any ideas?
#17649 3 months ago
Any ideas?
Check with all the distributors in the US and Canada
#17650 3 months ago
Any ideas?
Have stumblor get you what you are looking for and ship it to you.
$ 135.00
Dijohn
Decorations
This page was printed from https://pinside.com/pinball/forum/topic/stranger-things-club-join-our-party/page/353 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
