Quoted from ggg71:Thanks. I've attached a picture. I'll have to take a look and see what the process looks like on YouTube.[quoted image]
Yikes.
Touch wood , no pun intended, my pro is ok so far .
Yikes.
Quoted from chuckwurt:Less than 5% chance. Zero chance any engineering updates are applied.
Which is really a shame (the engineering updates) because the TK lock is a fundamental part of the game but was engineered by a twelve-year-old. The mechanism is terrible. I'm surprised someone hasn't engineered a plug-n-play aftermarket improved mechanism.
I've thought of taking mine off and giving it to my son for their product design program to look at and give to engineering.
Quoted from Soundkillr:Today I added a set of flaming speaker lights. I really like the way they look on this game!!
Like it. It goes with the theme of multiple modes on the game.
the TK lock is a really finicky mech but it is also possible to dial it in so that it works consistently, every time. it takes hours of work, though.
Can someone post a picture with the glow titan rubbers and the uv kit light on? I've only seen pictures on here with normal light and glow titan rubbers.
Quoted from gk_usa:Can someone post a picture with the glow titan rubbers and the uv kit light on? I've only seen pictures on here with normal light and glow titan rubbers.
the saucer gets a lot of abuse. whats the best way to protect it since cliffy doesn't have one for the game?
Quoted from jake35:the saucer gets a lot of abuse. whats the best way to protect it since cliffy doesn't have one for the game?
I think some people have been adding Mylar patches
I had glow Titan - recently swapped to Perfect Play purple / glows neon pink under UV , just for a change.
Line the whole edge with Mylar. It will keep it nice.
Being lazy here and haven’t trawled through the whole thread ……
Is changing the post rubbers either side if the drops straightforward ? Any tips or is it pretty obvious . Looks like some dismantling required.
Quoted from Ive:Being lazy here and haven’t trawled through the whole thread ……
Quite a bit of dismantling is required to get to those post sleeves. I just started removing things, making a list on a piece of paper of the order I removed things, then when I finally got to the posts (after removing most of the playfield components), I replaced them with long wearing Cliffy post sleeves, as I didn't want to do that all again for a long time, if ever. Also, while I had everything off of the playfield to get to that point, I put a complete set of plastic protectors on. I then reassembled things in the opposite order that I took things apart.
Quoted from chuckwurt:Line the whole edge with Mylar. It will keep it nice.
Did you round the mylar over the edge to get the top and inside or just butt up close to the top edge?
Quoted from Ive:I had glow Titan - recently swapped to Perfect Play purple / glows neon pink under UV , just for a change.
What plastic protectors do you have?
Quoted from gk_usa:Did you round the mylar over the edge to get the top and inside or just butt up close to the top edge?
Round it over. I cut a rectangle and set at in plane with pf surface, then make a couple of strategic cuts and stretch to fit along lip down into the well.
If you do it correctly you will have full coverage of the transition from top to bottom and ball strike areas and won't be able to see the mylar.
Quoted from joetechbob:Round it over. I cut a rectangle and set at in plane with pf surface, then make a couple of strategic cuts and stretch to fit along lip down into the well.
Sounds good, thanks
Quoted from Rum-Z:Quite a bit of dismantling is required to get to those post sleeves. I just started removing things, making a list on a piece of paper of the order I removed things, then when I finally got to the posts (after removing most of the playfield components), I replaced them with long wearing Cliffy post sleeves, as I didn't want to do that all again for a long time, if ever. Also, while I had everything off of the playfield to get to that point, I put a complete set of plastic protectors on. I then reassembled things in the opposite order that I took things apart.
Oh man. That sounds more of a mission than I am in the mood for
Quoted from gk_usa:What plastic protectors do you have?
Already fitted when I got the game. I think a guy on the UK scene made them - he does small runs of stuff for the local market.
No. The only worry is at the edge. Make sure it goes past the art, onto the wood, but not into the saucer cutout area.
We have plastic protectors in our shop, FYI
Quoted from Schwaggs:We have plastic protectors in our shop, FYI
https://pinside.com/pinball/market/shops/1167-gameroom-mods/07776-stern-stranger-things-plastic-protectors
Can you provide snapshots of all the different colors under the UV mode?
Quoted from chuckwurt:No. The only worry is at the edge. Make sure it goes past the art, onto the wood, but not into the saucer cutout area.
So kind of replicating Cliffy's protector seen here but with mylar?
Quoted from Ive:Already fitted when I got the game. I think a guy on the UK scene made them - he does small runs of stuff for the local market.
What color do they appear like when under normal light? Blue?
Quoted from gk_usa:Can you provide snapshots of all the different colors under the UV mode?
I have it on the todo list. I only fitted the red/pink set so far and looks pretty great to me. I have the blue set cut, just need to find time to install it and take some pictures.
We also have the protectors in clear if your main goal is protection. Once installed, they are virtually invisible.
S O L D
Hello All
I have sadly left the club and have a couple mods that I no longer require
Billy’s Illuminating Camero
and the Spiked Baseball Bat
I’d take $80 for Both to find them a home
Friends and Family only please
Shipping is on me US shipping only please
My loss your gain
Message Me if you want them
S O L D
Quoted from gk_usa:So kind of replicating Cliffy's protector seen here but with mylar?
http://www.passionforpinball.com/WIP/LOV-mag-st01.jpg
Kinda yea. Your worry is the part where the playfield artwork ends and the wood begins. Put Mylar over that. The Mylar piece will be the shape of a “J” when you make it.
So this is how i put my mylar around the saucer. As Chuck said, the jinal piece will look a bit like a "J" - below is the procedure I used for making the curve of the "J"
- measure the diameter of the saucer... I think it is 7/8" but double check
- go online and find a template for that diameter circle
- print the template and cut out the circle
- place the template/circle onto the saucer to see where it lines up with the wood on the playfield (The right edge and along the bottom)- mark the points on the circle... this is the area that needs to by mylared
- place the template/circle ontothe mylar with the two marks serving as the edge. Remember you are only concerned with the right edge (about 120 degrees) the rest of them circle/template can, and should have over the edge.(you will cut around them so you can match the diameter of the saucer perfectly).
- use scotch tape and carefully tape the template in place
- cut around the template carefully.
- I only extended the mylar about an inch beyond the saucer mainly because I suck at placing mylar without introducing bubbles. <ake sure to round all of the corners of the mylar, otherwise you will have lift points
- place the mylar as carefully as possible
-done
It seems like a lot of steps, but by far, for me, the trickiest part is putting down the mylar without bubbles. I took me 3 or 4 tries. Keep your circle/template because you can reuse it if needed.
Quoted from TheCnyPinGuy:S O L D
Hello All
My loss your gain
S O L D
Ooooo... can you show the ghostbusters proton beams? Those like they would be sweet. Can PM me, or put it on ghostbusters thread so as not to put a bunch of ghostbusters stuff on stranger things thread.
Quoted from chuckwurt:Kinda yea. Your worry is the part where the playfield artwork ends and the wood begins. Put Mylar over that. The Mylar piece will be the shape of a “J” when you make it.
Quoted from NC_Pin:So this is how i put my mylar around the saucer. As Chuck said, the jinal piece will look a bit like a "J" - below is the procedure I used for making the curve of the "J"
-done
Quoted from gk_usa:What color do they appear like when under normal light? Blue?
I’ll get you a picture in the morning
So here is mine. I created a smaller section for the entire inner edge of the saucer. I also created a full cut piece for the saucer trough and a section near the E because wear can happen there as well. I was very care and did a wet install.... And it's almost impossible to see the lines. You have to zoom in. I install vinyl from time to time for a living... So happy to give advice if anyone is looking for it. You should be able to see the lines if you zoom in...
20230216_191545 (resized).jpg20230216_191556 (resized).jpg20230216_191605 (resized).jpgQuoted from Schwaggs:I have it on the todo list. I only fitted the red/pink set so far and looks pretty great to me. I have the blue set cut, just need to find time to install it and take some pictures.
I would be very interested in other colours as well.
Quoted from davegauth:How can I get my hands on the Cleland code?
PM him and he will will send you a link.
https://pinside.com/pinball/forum/topic/stranger-things-cleland-sound-mod
Quoted from TyleroftheNorth:I would be very interested in other colours as well.
Thanks. I will update the thread when I have them all done.
Very pale blue
3F7FD1D9-9D38-4B40-975E-4F45976DBB35 (resized).jpeg631F001B-ED30-4914-8059-31B5D7605917 (resized).jpeg84AD9EDA-928B-4415-AD10-47D4D79CF906 (resized).jpegC07E5277-D373-45FA-8CBD-9D2A8FC61A51 (resized).jpeg
A8659F82-4874-4BD1-BF63-E9E9A40B79A3 (resized).jpegQuoted from Ive:I had glow Titan - recently swapped to Perfect Play purple / glows neon pink under UV , just for a change.
Those are the Pinball Life Perfect Play rings? Or are they still Titan's purple?
Which do you like better, the Perfect Play or Titan?
They won’t run this game again unless it’s pro only, too expensive for them to produce in my opinion as they’d need extra projectors and the pain for them to adjust the TK lock
People like to keep their game value high so if they have a premium/LE they are more likely to say they won’t run again…. For what is worth, a respectful pinsider posted on kanedas Facebook post that the next run will be 2024.
Quoted from Medic:a respectful pinsider posted on kanedas Facebook post that the next run will be 2024
Why do they think that? I don’t even think stern knows what they are running in 2024 outside of cornerstones, loosely.
Quoted from Gotfrogs:I reached total isolation for the first time tonight![quoted image]
I’ve only reached it a few times. First time I didn’t know how. Second time, I did notice that the inserts to the left ramp were flashing in the pinball equivalent of, “Shoot here, dummy.” I thought, “Hmmm. I bet that’ll be something good.” Total Isolation. So fun. “Thanks machine.”
Quoted from chuckwurt:Why do they think that? I don’t even think stern knows what they are running in 2024 outside of cornerstones, loosely.
This all comes from Stern wishing Millie Bobby Brown happy birthday on their social media, and they said something like "we'll see you in 2024." The logical interpretation is that Season 5 of the show is coming 2024, but now we have people saying this means Stern is re-running Stranger Things in 2024.
Quoted from reffob:The logical interpretation is that Season 5 of the show is coming 2024
Bingo.
This page was printed from https://pinside.com/pinball/forum/topic/stranger-things-club-join-our-party/page/345 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
