Quoted from TeeJayN:Regarding the STh Projector
Just to clarify a few things, as I posted about a year ago in this thread, I acquired a new spare OEM S6000 projector for my STh Premium direct from the manufacture as they were readily available back then. $150 shipped. Same exact unit and model number. While I was able to get the new projector to display the Stranger Things video perfectly, it was not automatic:
1. When you turn the game on the new projector doesn't come on. You have to manually press the side power button on the projector.
2. When you turn the game off the projector stays on because there is an internal battery in the projector to keep it running on loss of external power. Again, you have to manually press the side power button on the projector to turn it off.
3. When the projector does come on there is an intro screen with some display options and you have to manually select (with the provided remote control) the "USB" screen and then I get the Stranger Things video.
So, the original OEM S6000 DOES have an internal battery, WiFi, and a wireless remote control. The Stern S6000 does not have a battery. This is further noticeable as the OEM S6000 is distinctly heavier. Don't know if the Stern S6000 has WiFi or wireless remote but that's moot as neither is needed. Disconnecting the OEM's internal battery did not help as it still needed the power button to turn on. The intro screen and the required USB menu selection needs to be disabled but unfortunately there is no screen setting that I can see/find in the OEM S6000 to get around that.
So how did Stern get their S6000 to auto-power on and also go directly to the correct display setting?
I suspect it's all firmware - but I'll let others speculate and/or inform.
Meanwhile I'll just wait and hope for a solution or sell it as is. Else I have a nice brand new fully functioning $150 pinball paperweight.
you did NOT have the original s6000 projector. you had what sounds like the M4.
the original s6000 does *not* have a battery.
the original s6000 does *not* have wifi.
the original s6000 does *not* have a power switch.
the original s6000 does *not* have special stern firmware.
what ever projector you had was not the original s6000. it really sounds like you had the M4 or M4s, which did have all those features (aside from the stern firmware, which *none* of the projectors have, be it s6000 or m4/m4s.)
I have made the m4s works in a Stanger things. but you must do some small mods to the unit to make it work. but the m4s is physically a bit bigger so the mount is different.
