Hi guys.
I bought a Stranger Things Premium that had FW v1.01 in it so the other day I updated to the latest code v1.05. The update went fine and it said it was successful but I now have a random rebooting issue that I am not sure is related to the code. Let me explain... When I bought the game I only played a hand full of games before updating the code. After I updated the code, everything was closed back up I think I touched the left flipper bottom and the game rebooted. Now when I say rebooted I am not sure if it is rebooting or power cycling but I think everything goes blank on the game including the lights etc.. This happen 3x but I don't recall how it happen the second time, I think something similar but the 3rd time the game was in attached mode and I just leaned on the left side of the cab, maybe touching the left flipper button, I am not 100% sure. Now I will say this, the game does have flipper buttons installed that light up so I am not sure if these could be causing an issue. I also resat the game to the factory values after I updated the firmware so it is possible I changed a setting somewhere that needed to be changed for a mode that is installed? What I plan to do it go through the game, reset all the connections and then if it still happens disconnect the lights to the flipper buttons. I will say this though and I think this is certainly worth mentioning but the game has NEVER rebooted/ repowered during a game play. I have played several games and this only happens when the game is in attract mode and I believe only when you touch it?? Maybe a ground issue???
In anycase... I plan to tackle this issue Friday so I figured I would post something up here just to see if anyone has any tips or suggestion in case what I plan to do does not fix it.
ps. I still have to adjust the TK lock as well. I have been reading through this thread but at 290 pages now, it's a lot to try and find the exact information I need so any tips in setting this or the game up is helpful as well. I want to dial this thing in as close to perfection as possible.
