this is were that wiggle is coming from, it has always been like this since day 1:
I guess I could tighten it but this means that the whole ramp and diverter needs to be taken off, just to get to this bolt. I am not exactly sure how to take the diverter off either and dont want to waste a lot of time getting to this bolt that might not be the problem in the first place.
I will just wait for the ramp, if it does not work I will contemplate all other options and take the ramp out and start from there...
What I meant earlier when I said the ramp cannot go forward anymore is this:
As you can see, the ramp is touching the switch body. I tried loosening the switch to see if it could be moved as well, and it is not possible. There is not room for anything there. Now, the ramp did come forward maybe almost 0.5 mm, but it is maxed out now unless I modify that part but if I do then the screws will no longer line up properly with the PF so... we will cross that bridge if we really have to...
I am annoyed.
