Quoted from HarrieD:
That LE speaker mod. Of which components does that consist?
For the backbox I found Kenwood KFC-S1066, is this correct? And the cabinet speaker? Is a filter included?
The Kenwood speaker that Stern has been using in the LE games is model KFC-1366S. I think the ones you have mentioned are 4" speakers, in American terms and not the 5.25" size that the LE games use.
What is needed for the upgrade is (all prices listed are for the entire quantity needed):
2 - 5.25" speakers: Of your choice, $7.50 (if you want to really cheap out) and up.
2 - 5.25" speaker plates: To be able to mount the larger 5.25" speakers. Available now for $69.90 and I will have them available soon for $50 or $25 if you are buying a SPIKE 2 Speaker Light Kit from me.
2 - Foam gaskets: Available now for $25.90, BUT not required if you are installing a Speaker Light Kit. These may also not be needed with certain speakers (depending on how far the tweeters stick out), but they do use them in the factory LE speaker setup.
8 - 1/2" spacers: Available now for $3.52, BUT also not required if you are installing a Speaker Light Kit. These may also not be needed with certain speakers (depending on how far the tweeters stick out), but they do use them in the factory LE speaker setup. These spacers and the above gaskets kind of go hand in hand, you really either need them both or neither.
2 - Speaker surrounds (if you would like to match the LE look). I can get these in about any color you would like for $22.50. Available in red elsewhere for $23.90.
All and all, if you are wanting to do this 4" to 5.25" upgrade and you DO need the spacers and gaskets for the speakers you choose to buy....you can get all the parts elsewhere for $123.22 (excluding the price of the speakers you choose) OR you can wait a bit and get the needed parts from me (including the type 13 Speaker Light Kit and acrylic surrounds in your choice of color) for $122.50 ($.72 cheaper).
Heck....even if you hate speaker lights, you can unplug them and it's still cheaper than what is currently available.......but come on, at least turn them on white and dial down the brightness. Even that has to look better than nothing.
Doug (SpeakerLightKits.com)
