Last night I noticed a strange reset on my Road Show. My Road Show doesn't reset during game. Prior to last night, I would have said it doesn't reset at all. It was basically an accident I ran into this.
It only resets if I power it on, quickly go to tests, and do "all lamp test". Lights barely turn on and it resets.
This happens about 50% of the time when I repeat the process (from cold start --- aka power off)
Interestingly, when it happens... if I let it reboot on it's own and go back into tests, it will typically reset again one more time when I do "all lamp test". But if I let it reboot and do it a 3rd time, it runs.
If I repeat the process and do individual lamps or the row/column, it never resets.
I'm wondering if 18v used for the lamps can't handle all lamps enabled until caps charge up? Maybe this really is a c6/c7 issue? (I think those are the two)
Again, never resets during gameplay or if I run the all lamp test a little later.
Oh, I have one of the RKAHR 5v product. I don't run with it normally, but I used it for debugging. It resets with it attached and the "low 5v" light doesn't come on...
Thoughts?
