I just remove and reinstall the playfield and now the right flipper,kick out and start eject kickout doesn't work and ''when lit'' doesn't lit.God,WTF i did?
take your time & retrace your steps, check all your connectors etc, maybe pins may have backed out a little, suspect wiring broken or damaged, hopefully something easy & staring you in the face
It might be an issue with the Jones plugs on the main board. Unplug and plug back in... Check the Jones plugs for oxidation - that faded white residue that sometimes builds up on the plugs... Clean and insert the plugs firmly back into their sockets... Or some switch just became out of adjustment when you moved the playfield. Do you have the schematic for the machine?
Is the Jones plug from the play field been cleaned? Is it in place properly?
I will go out on a limb here. The only thing that connects most of these is 'Motor Switch 2B' Most likely not the problem.
Not the right flipper, check the wires at the button and the coil connections.
The sequence bank for the 'When Lit' is attached to the underside of the playfield. Is it possible that it has a few wires knocked off? Is that bracket pushed into place and secured tightly?
This page was printed from https://pinside.com/pinball/forum/topic/strange-world-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
