Issue: clock will stop at 11 or 1 when ball is drained during modes involving clock when hour hand is near "6".
Apon boot up: game will find 12o'clock 100% of the time and will find/keep real time 100% of the time.
In test: all optos register 100% during slow forward and slow reverse. During fast forward and fast reverse only the DMD shows the 30min opto is missed at 5 and 11. It seems to happen regularly around the 5/6 and 10/11.... I've let the clock run in test for over a couple minutes and it never stops but I can see the 30min opto isn't registering twice during the complete fast cycles.
Interesting addition: when ball drains and clock stops at 11 or 1- the clock will set itself back to 12 after next player/ball drains. (It's as if the CPU knows the clocks not it the correct position.
All hour optos register and displays are identical to what manual shows.
The oritentaion of the inner gears have been checked, adjusted and rechecked using the manual as a guide, yet I still continue to have the same issue every so often.
I installed ingos board back in may of 2015 and recently tried using another ingo board and I'm still having the same issue.. I think Ingo is a great asset to the hobby and believe the problem doesn't involve his board.
Hoping I can learn and figure this out with the help of you guys and gals.
