Solved the fuse issue. When I lowered the PF and fired it up, all the lamps were working now except two at the 3 drop arrows. Had lamp test running and the 2 bonus circles were dimmer than the rest. Jumpered the power braid from another strand and they went immediately brighter. I connect the dimmer braid to the one I had jumpered with a short piece of braid and soldered them together. Next start up it reverted back to the same lamps out as before. Very weird. Did these tests:
I think barakandl also mentioned to remove switch harness connectors at J2 and J3 from the MPU board - any change with the suspect lamps?
No change
Probe the grey-yellow switch strobe #2 wire at any of the drop target bank switches with your logic-probe.
Compare the logic probe indication to a switch strobe #1 wire, say the orange wire at the left flipper return lane switch. The results should be identical.
They were the same.
Then just out of interest with the machine OFF, measure the resistance between these two switch strobe wires with respect to ground (one multi-meter lead on ground, the other multi-meter lead on the switch strobe wire - resistance readings should be about the same)
They were the same.
As far as testing the Lamp board U1 pins, how are they they numbered? I'm running a Weebley.
