OK, on to my next issue...
I have one display (the Player 2 display) on my Mr & Mrs Pac-Man that is displaying strange behavior. It displays a score based on whatever digit is in the "hundred-thousands" place across all digits. So for example, as you can see in the linked video, when the other player displays are showing "421,130" for HSTD, the Player 2 display shows "444,444."
In-game, if I have a score under 100,000 it displays nothing (effectively a "0" in the hundred-thousands place). If I have a score between 100,000 and 199,999 it displays "111,111." If I have a score between 200,000 and 299,999 it displays "222,222." Etc.
Any idea what might be causing this? I swapped the displays around a few times and the issue stays in the Player 2 position. So it's not a bad display. The wiring to the display appears correct, as does the wiring to the A4J1 and A3J3 connectors.
