Getaway.
Left Flipper the plunger sticks in the coil and makes a whistling sound. Flipper mainly works fine at full power but sometimes gets stuck at the top of the flip where the hold is.
I have taken apart the flipper assembly and have checked everything. Put new coil stops in and coil sleeves. I test and its ok then after a few games plunger is catching again.
Ok so now I take the whole assembly out. Replace everything except the bracket from a right flipper new spare also I did not replace the eos switch. The flipper has new plunger link and even a new flipper in case the shaft was bent. Got it so it didnt catch.
5 or 6 games later the whistling squeaky sound comes back and indeed the plunger is getting caught again hence the squeaky sound.
I have replaced with a new coil. Only thing I can think of is that the bracket assembly has moved to missalign the flipper hole through the bushing maybe from the wood warping or shifting slightly?
Any ideas? got me stumped.
Regards David
