Hello!
I've been struggling with my creature for about two weeks now and I am totally stumped. Since I have got the machine it has booted rather slow and now doesn't want to boot at all. If it does get running it runs and plays perfectly. I swapped out the power driver board for a board I knew worked, test point voltage remained about the same.
TP1 (12vu) = 14v
TP2 (5v) = 4.9-5v
TP3 (12vr) = 11.8v
TP4 (zc) = .4v
TP6 (50v) = 70v
TP7 (20v) = 20.6v
TP8 (18v) = 14.2-17
These were almost exactly the same between two boards, fuse F113 has blown twice in about 20 boot ups causing the 5v to not work at all, after replacing that it booted, but still slowly.
After this I swapped the CPU board with a brand new ROM and it got even weirder. On the old board it just power cycles with the top and bottom LED being lit on the CPU. With the new board the top and bottom LED light and the flashers on the machine go crazy, I think I even heard a solenoid fire. There is no power cycle or indication it wants to boot at all. After putting the old board back in it just power cycles over and over with no sign of booting.
Here are some pictures of the boards:
Power Driver -
CPU -
The Rest -
Thanks for any help you can offer!
