(Topic ID: 144862)
Strange Behaviour in 8BD
By leaffan67
6 years ago
  • 17 posts
  • 7 Pinsiders participating
  • Latest reply 6 years ago by leaffan67
#1 6 years ago
Hi All. Just now (happened twice) I knocked down several of the bonus multiplier drops, then hit the A,B and C lanes which (correctly) drops two of the pool ball drops on the rt side. However, it also reset the bonus multiplier drops. I was on 3x. Suddenly, I have to do 2x and 3x again just to get to 4x! Surely this isn't correct behaviour. Any ideas?
thx in advance, Dave
#2 6 years ago
Bueller?
#3 6 years ago
Enter test mode and step to solenoid test. Let it cycle through a couple of times following along in the manual. Make sure all the correct #s are displayed for the solenoid in action.
Then go into switch test (ball out of game, all targets up) and drop the multiplier targets one at a time and make sure the correct # is displayed for them as well.
Also, the solenoids driven by the Solenoid Expander Board should have two diodes affixed to their lugs. If one-diode coils are fitted at those designations, very weird solenoid behavior ensues.
#4 6 years ago
Roger that last bit Cody. A one diode coil in a Medusa had me going in circles.
#5 6 years ago
thank you! will do and report back!
#6 6 years ago
Would anyone be so generous as to provide a photo of the wiring for the right side drop target bank showing the double diodes and the wiring to the solenoid lugs? Please and thank you. It appears I have a "hacked" drop bank. strange that it worked properly for years before this problem started....
#7 6 years ago
What was the result of the solenoid test? Did everything fire properly? Any switch errors?
#8 6 years ago
Yes, all the solenoids fired properly. However, when the 2 ball solenoid fired, it also reset the bonus multiplier drops.
#9 6 years ago
Sorry, mine is currently folded up. If you still need one this weekend I could probably get you one.
#10 6 years ago
it would really help me to have a couple of photos. two of the rt bank solenoids have double diodes and the other 5 don't. I think there is some strange wiring too.
#11 6 years ago
Quoted from leaffan67:
My EBD is currently staying with a friend. I had trouble sorting out solenoid issues (ended up being a failed solder joint.)
Solenoids 1 and 2 had two diodes, whereas the rest had one.
#12 6 years ago
on mine only 6 and 7 have two diodes.
#13 6 years ago
The coils that should have two diodes are:
7-drop target bank reset
8 ball saucer
1 ball
2 ball
Multiplier drop bank reset
Outhole
If the saucer or multiplier bank or outhole coils don't have two diodes, the multipliers will reset every time the game drops the 2 ball (via A-B-C-D).
#14 6 years ago
If you still need pictures let me know. I have two complete (and fully-functional) EBD assemblies that are out of machines that I can sit on my bench and take pictures for you. One assembly is the early Bally design and the other is the final Bally/Midway design. They are both the same except for the connectors.
#15 6 years ago
Yes pictures please!
#16 6 years ago
Alright, since you say you have the 3rd edition with the under playfield circuit boards with twist-in lamp sockets, I took some pictures of the same version drop target assembly. The two versions are basically the same except the 2nd version includes a connector and can be easily unplugged where the switches on the older version are hard wired. The 2nd version also has a plate that allows you to adjust the target height with sheet metal "fingers" between the targets to prevent the ball from hanging-up.
This is a fully-rebuilt and tested assembly and I think this is the view you are looking for (click on it to enlarge and then click again to zoom-in):
#17 6 years ago
Yes that photo should help a lot! Thx!
