absolutely!!!! Magnet holds the ball for a few seconds, shaking it. 1. Prepare to tap side. 2. Upon magnetic release TAP SIDE of cab.
Shazzzam. makeable shot.
also you can change the number of seconds that it will save the ball. sounds like yours is off or just for a few seconds.
Quoted from docscott:also you can change the number of seconds that it will save the ball. sounds like yours is off or just for a few seconds.
i got ball save up to 6 or 8 seconds, well i will tell the wife she is not alone then
i usually do a little tap myself but sometimes still doesnt help
The magnet is supposed to fling/shake the ball. Rarely does it go SDTM on mine.
In adjustments menu:
A.2 22 has the factory settings for it as Disabled- Should give the ball back if enabled. Is your machine keeping the adjustment?
Is is flinging the ball, or just locking the ball and releasing?
you gotta tap it after it lets go, near the top, where the slightest sideways nudge will dramatically change the trajectory. The timer is working while the ball is held, but TOTAN times seem short to me. Just don't tap while the ball is still held. wait for it to start rolling slowly, then.. nudge. You'll get it down. That secret is one of my tricks for kicking newbie butts on it... lol. So don't tell anyone.
Quoted from jimjim66:The magnet is supposed to fling/shake the ball. Rarely does it go SDTM on mine.
A.2 22 has the factory settings for it as Disabled- Should give the ball back if enabled. Is your machine keeping the adjustment?Is is flinging the ball, or just locking the ball and releasing?
it seems to do a little of both when it feels like it, sometimes just a solid hold and a roll other times starts whipping the ball around
Quoted from docscott:you gotta tap it after it lets go, near the top, where the slightest sideways nudge will dramatically change the trajectory. The timer is working while the ball is held, but TOTAN times seem short to me. Just don't tap while the ball is still held. wait for it to start rolling slowly, then.. nudge. You'll get it down. That secret is one of my tricks for kicking newbie butts on it... lol. So don't tell anyone.
LOL will go play a few more games and try it out
Quoted from dvandentop:it seems to do a little of both when it feels like it, sometimes just a solid hold and a roll other times starts whipping the ball around
So it does throb/pulse?
What ROM version. Version 1.4 is supposed to have a variable magnet setting. Magnet countdown goes from the time it grabs the ball.
someone on rgp suggested new firmware looks like this is what i need. i have version 1.3
G11 Version 1.4 Date: October 15, 1996 (10/15/96)
Checksum: 6914
Changes since Version 1.3:
Added Adjustment A2.27 (MAGNET THROW). This adjustment can be
used to strengthen the magnet power when the game tries to
throw the ball off the magnet at Tale start.
Fixed a bug in Final Battle when a tilt occurs.
Balls are returned to the shooter faster in Final Battle.
Improved diverter rules between Harem Multiball and Rocs mode.
Slight improvements to speech.
Timing to the jet bumper post improved to help jet bumper action
Quoted from jimjim66:So it does throb/pulse?
looks like i need to upgrade to 1.4 where can i get the new roms?
Mine throbs too. Just occasionally goes to the side. At least half the time it throbs then let's it go sdtm. Sounds like exactly what dvandentop experiences.
Quoted from docscott:Mine throbs too. Just occasionally goes to the side. At least half the time it throbs then let's it go sdtm. Sounds like exactly what dvandentop experiences.
boot up your game and see what version it shows when 1st starting up??
i had 1.3
would be aweosme if we both get ours fixed!
That is probably it. It is also telling that they have a ball save for this. They knew when designing it that it would sometime do it, so it is not an uncommon problem.
Quoted from dvandentop:Docscott i will let you know when i get mine if it improved, i ordered from here
http://www.pinballroms.com/
Please do that. I never thought it might be something wrong, as it does fling it sometimes. Let me know.... meanwhile, I'll just keep tapping mine...
Correct on the firmware, I had that problem basically go away with the new firmware. Before it would just dribble down the middle, now if flings it good and almost never goes down the middle. In fact, I cannot even remember the last time it went down the middle from the magnet. The firmware fixed it good!
Quoted from Pin_Crazed:Correct on the firmware, I had that problem basically go away with the new firmware. Before it would just dribble down the middle, now if flings it good and almost never goes down the middle. In fact, I cannot even remember the last time it went down the middle from the magnet. The firmware fixed it good! []
kick ass will be even better after the firmware! cant wait to get it now!
DR Scott this helped for sure go ahead and order the 1.4 rom and set the magnet throw to level 1 and it seems to help alot!
hell i got my best score on the machine after installing the new rom!
Quoted from dvandentop:DR Scott this helped for sure go ahead and order the 1.4 rom and set the magnet throw to level 1 and it seems to help alot!
thanks, I'll do that! Appreciate the update.
Quoted from docscott:dvandentop said:DR Scott this helped for sure go ahead and order the 1.4 rom and set the magnet throw to level 1 and it seems to help alot!
no problem man, and then damn wife beat my high score i set last night too
Yea really made a difference on mine!! Glad it has improved, I think you will not be disappointed upgrading the Roms!
Quoted from dvandentop:no problem man, and then damn wife beat my high score i set last night too
Hahaa now you got some work to do my friend. May the force be with you.
I had a weird thing happen on TOTAN last night. I was having an awesome game and I shot the ball at the Genie to start Final Battle. The magnet failed to grab the ball before lowering into the playfield, and the machine got confused. It shut off power to the flippers. I thought it would give me the ball back in the trough, but instead my ball ended. I was shocked that it didn't compensate. Is this a bug in the software?
Well, it looks like my problem with the ball draining the other day wasn't a bug in the software after all. Nope, I'm afraid it's a bigger problem. I went to play a game last night, and none of the solenoids would fire. I'm guessing I may have blown a fuse.
Yea that makes sense Gweempose, anytime I have the magnet not grab the ball it does not start the multiball/final battle and the game continues, you must hit it again and the magnet has to grab it and drop it below for it to go.
my dang wife got all the jewels last night but she lost the ball just after the princess was talking about saving her! was awesome and now i am excited to get that mode again!
I concur. The next software fixes it just find the right setting. I think mine is set to 2 and it never stdtm. I tried 1 and 3 and thinking 3 was the more powerfull but its just how it throws it not the power.
I have the 1.4 version, thanks to stangbat, , and rarely experience stdm's off the magnet. Setting is on "1". Tried 2 one time but it didnt seem to throb and fling. What I occassionally experience is a vanishing magnet error when I cannot detect any issues. Everything works like it should. Run thru tests and all appears fine. Credit dot goes away with next game played.
Quoted from Silverballer:What I occassionally experience is a vanishing magnet error when I cannot detect any issues.
Mine does this as well. I can't tell if it's because a certain number of balls have been played without starting multiball, or if it's just some weird design flaw. I get a similar error for the Borg lock on STTNG, and it's definitely because it's such a hard shot to hit that the opto rarely gets triggered.
As for the throw setting, I never played around with it until this thread. Mine has always been set to the default (1), and I almost never get SDTM drains. Last night I tried the other two settings, but I actually prefer the default.
This page was printed from https://pinside.com/pinball/forum/topic/straight-down-the-middle-totan-off-genie-magnet and we tried optimising it for printing. Some page elements may have been deliberately hidden.
