(Topic ID: 137117)
Storage Locker Advice
By mof
7 years ago
    #1 7 years ago
    I'm wondering about using local storage for pins. Have you come up with a simple formula based on experience, to help you choose the right sized space?
    I'm thinking of being prepared to store ~20 pins, but I would want "easy" (in quotes) access to a pin if I wanted it out.
    For example, if a pin takes up ~30" x ~30" of floor space while upright:
    * What's the ideal width of the unit to be able to walk back and reach a pin in the farthest position? (Or do you simply stack them tight, and move out 5+ pins to reach 1, etc)
    * What's the best way to utilize the unused vertical space (or do you ignore it)?
    * What's some pros and cons between: 5'x15', 10' x 15', 15' x 15'?
    * What are some options for how the space is used in terms of pin positions?
    Thanks for the insights...
    -mof
    #2 7 years ago
    Not a direct answer to your questions but I would definitely put down some kind of barrier on the floor just in case there is any kind of leak on those sheds. Food for thought.
    #3 7 years ago
    I had to use a storage unit for about 20 pins during a move and I believe it was 30x15 and stored them upright with heads on top of coin doors stored along the walls in a horseshoe pattern, of course I had other crap in the unit as well but was easy to access the machines. Go with a bigger unit, Also lay down some rodent traps/bait to keep rats and mice out of your stuff.
    #4 7 years ago
    Is there any way you have to put up a shed or store them on your property instead of renting?
    The fees for storage quickly add up, it might be better simply selling the games and rebuying them later.
    #5 7 years ago
    Dibs on Gorgar!
    #6 7 years ago
    make sure it's climate controlled. Humidity will kill the electronics over time
    This page was printed from https://pinside.com/pinball/forum/topic/storage-locker-advice and we tried optimising it for printing. Some page elements may have been deliberately hidden.
