Quoted from ahdelarge:Hi all, a friend with Pin2DMD in his Addams Family has asked me to help him out. I'm not familiar with it, but trying to do some research. He showed me some frames in the game where the color changes (I'm guessing these were missed frames in the colorization process). Is this something you need to wait to be fixed in a code update? He said it's software version 4.09.
Cheers!
Adam.
First thing make sure there is no credit dot. A credit dot will cause issues with some frames.
version 4.09 will be the PIN2DMD firmware version. It is an old version, looks like the latest is V4.26 https://github.com/lucky01/PIN2DMD/blob/master/firmware/latest/EVO128x32_EVO128x16/PIN2DMD.upd will get you to the firmware for the EVO board. Assuming he has that board. If unsure check the board type first before loading the update. Failure to check may leave you with a bigger problem.
To load the update, turn off the game, eject the SD card, put the downloaded file onto the SD card, install the SD card and turn on the game. If all goes well you will see something like "updating" on the PIN2DMD.
Updating the firmware may not fix the issue you are seeing as that may be in the colorization files - check that the files are the latest from Netzwerg, when your friend paid for the files he should have got a google drive link to the colorization files so you can downlaod and install the latest.
If your problem remains, you will need to report the problem to Netzwerg.
