I just got a STNG pinball Machine today. I Did the test function and I get a F7 Spinner Error. I can't find the error listed any ware in the manual. Has anyone ever seen this before? I would be vary thankful for any help or input..
Most likely a broken wire involving the spinner.
Dig out your manual, see the switch matrix in the rear ? See the right side for dedicated switches ? See the spinner is on that side, check other switches listed on that column for a broken wire killing the spinner switch. Probably on one of the EOS points.
You can spin the spinner in switch edge test and see if it works or not, I'm just banking on a broken wire.
LTG
Had the same thing on mine, turned out the switch was just pushed out of position so it wasn't being activated by the spinner.
This page was printed from https://pinside.com/pinball/forum/topic/stng-f7-spinner-error and we tried optimising it for printing. Some page elements may have been deliberately hidden.
