Quoted from sepins:
Took the 2 screws out holding switch and moved it 1/4 inch closer to plunger. Edge of switch is almost touching inner part of pf. Only used 1 screw to put switch back up. Think Stern may change software as this is an issue so figured one screw tight would do for temp fix.
I was doing other work on my playfield today and thought I'd take a look at moving the kickback sensor (outlane sensor). I didn't do anything because I wasn't exactly clear on what you did here and wanted to take pics and ask for confirmation. (Sorry the one picture is a bit out of focus.)
So, is this what you did?
1. Unscrewed the two red screws holding in the outlane/kickback sensor switch
2. Moved the switch toward the kickback coil
3. Screwed back in just ONE red screw to hold it in place
If so, how do you deal with the fact that, at least on mine, it looks like the front edge of the outlane switch "wire" (that the ball rolls over) will probably hit the end of the channel?
