(Topic ID: 253338)
Stitching Headers
By oldschoolbob
6 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 5 months ago by oldschoolbob
    There have been 9 images uploaded to this topic. (View topic image gallery).
    #1 6 months ago
    I don’t think I’ve ever seen anyone show how to stitch a header after losing a solder pad. I lost several pads on the last board I was fixing. I thought I’d document how I do it. I’m not saying my method is the best. I’m sure others have their own way of doing this and I’d like to see your method.
    I start by feeding a single strand of wire through the header pin hole.
    Then I insert the header. And wrap the strand around the pin on the solder side.
    Then solder the header in place. And trim off the wire.
    Then the tricky part is soldering the other end of the wire to the trace. Be very careful here not to short to any adjacent trace.
    After completing my work I always buzz test all connections with a DMM. Also check pin to neighboring pin for any shorts.
    I’m sure there are better ways of doing this. I look forward to your comments and suggestions.
    Bob
    #2 5 months ago
    That works but you should get some replacement pads and use those. Maybe not the full rivet route, but at least get a solid pad on the missing side for some mechanical strength and re-workability.
    #3 5 months ago
    Thanks slochar, I didn't know you could get replacement pads. I kept the old pads and thought about gluing them back on but if you don't get them on straight it could cause a short. It seems with the wire wrapped around the post and soldered it should be stronger than before.
    Bob
    $ 125.00
    Sparky Pinball
    $ 84.95
    $ 339.00
    $ 159.99
    $ 225.00
    FlyLand Designs
    $ 149.00
    Sparky Pinball
    $ 107.95
    Hookedonpinball.com
    $ 38.75
    The MOD Couple
    $ 6,995.00
    Flip N Out Pinball
    $ 799.00
    $ 24.99
    Lee's Parts
    $ 139.00
    Sparky Pinball
    $ 17.00
    $ 248.85
    PinWoofer
    TheDudeMods
    $ 239.00
    Tilttopper
    € 60.00
    YOYOKOPTER MODS
    $ 69.99
    Professor Pinball
