I had posted this on the Ads list, but figured it might get more exposure here. If this is not allowed, please forgive me.
I need the power/rectifier board replaced in my Silverball Mania machine. I have a new Rottendog rectifier board, but am no good at electronics or soldering.
The reason I believe the board needs replacing is because none of the feature lights are working, and one of the rectifiers seems burned out, and one of the pins and the casing also has a burn mark.
I'd also like a general machine check because when I bought this machine I was told it was checked by a service tech, but some of the wires were fooled with and it seems that tech did a sloppy job. There's a loose grounding wire in the backbox - to give you an idea of the sloppiness. But what do I know?
I'd need someone who knows pinball electronics, and hopefully this machine in general, that can come to my apartment to do this.
I also have new MPU / Lamp Driver and Solenoid driver boards from Alltek. If the installed boards checkout OK I wouldn't need these installed. I could probably install those myself.
Is there anyone here, or anyone who knows a good tech that can do in home service in Brooklyn?
I would appreciate any assistance.
