(Topic ID: 251043)
Sticking Pop Bumpers solution.
By Nintendork
9 days ago
  • 56 posts
  • 14 Pinsiders participating
  • Latest reply 1 day ago by Nintendork
There have been 21 images uploaded to this topic. (View topic image gallery).
There are 56 posts in this topic. You are on page 1 of 2.
#1 9 days ago
I have a 1969 Gottlieb Road Race that currently has 2 pop bumpers (wired together) that stick every now and then. (about every other or every third bump) I have replaced the coil sleeves. Cleaned and de magnetized (with a hammer) the coil stops. Cleaned parts with rubbing alcohol. If you look in th pictures one of the coils looks a little black. Could this be a sign to change coils? The other question is what setting to put this multi meter on to check polarity and what the rate should be around on the meter?
Thanks all!
20190908_133842 (resized).jpg20190908_133729 (resized).jpg20190908_133738 (resized).jpg20190908_133749 (resized).jpg20190908_140339 (resized).jpg20190908_140356 (resized).jpg20190908_143834 (resized).jpg
#2 9 days ago
Quoted from Nintendork:
Consult your schematic. What coil is supposed to be there? Check at https://www.flippers.com/coil-resistance.html and see if the resistance you measure is close to the resistance it's supposed to be.
Schematic again but 200 AC is most likely the right range (the red numbers at the upper right). http://www.pinrepair.com/em/index3.htm#low
#3 9 days ago
Stick how exactly? Are they getting power and pulling down or are they not getting power and are mechanically binding somehow? These would have very different solutions.
What are you trying to measure? These are AC coils so there's really no polarity. Either way, it seems unlikely that a bad coil is the problem unless the plunger is binding inside the coil.
/Mark
#4 9 days ago
When they stick if you turn the machine off do they release? Then you can tell if it is a mechanical problem or not.
#5 9 days ago
I had that problem and it was a sticky plunger. Took it apart, cleaned with 91# rubbing alcohol, gave a light sanding with 600# paper, and all good.
It could also be that the two posts that go thru the playfield are catching on something.
#6 9 days ago
Coil stop looks funky, file it til it's flat and or rotate it 90°.
First dmm I ever saw with a separate ohm and volt jack. . What a pain in the ass that is.
#7 9 days ago
Quoted from dr_nybble:
I will give that a try and get back to you
#8 9 days ago
Quoted from currieddog:
Cleaned what exactly? The coil or the sleeve? The 2 metal rods don't seem like they are rubbing
#9 9 days ago
Quoted from CNKay:
File it down with a standard file?
#10 8 days ago
Quoted from MarkG:
/Mark
They engage and pull down in the coil like normal but stay down and make a loud humming sound until I press 1 or 2 of the flipper buttons which releases them. As for the multi meter I am trying to find if the coil is bad which if it is I was told it would be not enough power on the meter I am just wondering how to measure it on the meter
#11 8 days ago
Section 8.3: https://www.manualslib.com/manual/1113859/Sperry-Instruments-Dm-350a.html?page=6#manual
You'll need to know what coil you're measuring and what the resistance of that coil should be.
You'll find the information about what coil it should be on your schematics (or manual, if it has one) and you'll (probably) find the expected measurement at the link in post 2. If it's not there post what coil you have and someone will look it up for you.
#12 8 days ago
If they hum while they're stuck then probably it's an electrical issue. I'd gap the switches (both eos and trigger) on each pop wider, and examine the switches on the pop relays
#13 8 days ago
Quoted from zacaj:
How is that done exactly? Gaping and examining the switches?
#14 8 days ago
http://www.pinrepair.com/em/index2.htm#clean
#15 8 days ago
Quoted from YeOldPinPlayer:
OK thank you
#16 8 days ago
Sounds like your coils are fine so you can probably put away the meter.
Each pop bumper has two switches mounted to it. The ball closes the top switch (closer to the playfield) that sends power to a relay that in turn sends power to the pop bumper solenoid. The other one (the End of Stroke or EOS switch) should open once the pop bumper reaches the bottom of its stroke, and cut power to the relay.
It could be that one of your EOS switches is shorted or isn't opening, or that one of the top switches is shorted or stuck closed.
For a better explanation, and to see how the pop bumper works in slow motion watch the video at:
https://www.funwithpinball.com/exhibits/small-boards#PopBumpers
#17 8 days ago
Road Race, cool theme! My Sky Jump has tandem pops. Each one has an end of stroke switch. When I got it, one switch was open so far it was obviously disabled. I did my best to gap them correctly, but that created a similar problem to yours-both would lock on. I opened one back up and viola, smooth poppin’ and no lockin’ ever since.
#18 8 days ago
The plunger and the sleeve.
#19 8 days ago
I'll give it a shot. Thanks
#20 8 days ago
Quoted from jasonspoint28:
Were would the switch be located for adjustment? Here?
#21 8 days ago
Quoted from MarkG:
I will give that a try thank you
#22 8 days ago
Were would the switch be located for adjustment? Here?[quoted image]
That switch needs to open fully when the pop bumper is energized, or it'll stay locked on.
#23 8 days ago
Quoted from zacaj:
Gotcha!
#24 7 days ago
Quoted from MarkG:
https://www.funwithpinball.com/exhibits/small-boards#PopBumpersthe switches all look like they are gapped just fine like in the bumper video. If there is a short of some kind how would I check or repair it?
#25 7 days ago
1. Mechanical Binding
- Plunger/sleeve
- Platter/pop body
- Platter/Spoon switch
2. Plunger coil stop
3. EOS switch Adjustment
4. Control Relay
- Binding
- Magnetized armature
- Switch Adjustment
My money is on 4 - magnetized armature, since I think you have more or less covered everything else except the platter and you probably would have noticed that.
#26 7 days ago
Quoted from newmantjn:
- Plunger/sleeve
- Platter/pop body
4. Control Relay
- Binding
- Switch Adjustment
I demagnetized each armature and coil stop with a hammer. (found from a different forum post) the switches look like they are adjusted correctly from looking at correctly adjusted switches and videos from other pop bumpers. Binding would be the metal rods rubbing on something correct? I believe it doesn't from what I see. Anything I missed? Shorted switch perhaps?
#27 7 days ago
- Plunger/sleeve
- Platter/pop body
4. Control Relay
- Binding
- Switch Adjustment
Would it help if I attached a video of it sticking?
#28 7 days ago
What i did for the magnetized pop bumper assemblies on my Black Hole:
Layer a couple small pieces of scotch tape on the surface of the coil stop where the plunger makes contact. Made a world of difference in the performance on my game-no more sticking pops. There's probably better/cleaner solutions, but it's done great for my BH so far. I even went ahead and did it on the pops i wasn't really having trouble with and i swear they also work a little snappier in result.
Hopefully that helps if you're still dealing with magnetized plunger/stop, which may be possible...
Also, as zacaj asked earlier, does the coil continue to hum after it's activated and stuck? Or is it quiet, but will only release if you manually pull it up?
#29 7 days ago
Quoted from frunch:
Thanks. I will try that. It hums all the time until it is un stuck. I can either pull it up which I have to pull hard to unattach it or press one or both of the flipper buttons and that will get it unstuck
#30 7 days ago
Ahhh, forget about magnetized stops/plungers for now--i overlooked part of the thread that pretty much addressed that.
Well if it's continuing to hum, it may not be opening the end of stroke switch as zacaj was mentioning earlier. With the game off and the playfield opened up, move the pop bumper rod and ring up and down manually, you should see a switch on the pop bumper mech open as the rod and ring is pulling into the coil and closing as it springs back to its resting state. Sometimes a leaf from that switch can get on the wrong side of the pop bumper yoke that activates it.
If the switches are adjusted properly, next thing to check would be whichever relay activates the pop bumpers. There may be a switch on that relay that needs adjustment. Not sure which relay that would be, but you should be able to find it on the schematic.
#31 7 days ago
Curious that a flipper button will unstick it. Wish I had the schematics.
#32 7 days ago
Quoted from frunch:
I finally got him to take some pictures here is both switches one with the coil engaged and the other with out. Both bumpers are identical to each other as far as adjustments go they look about the same. This is me manually engaging the coil. Also where would I find the schematics online as I don't have any they came with it?
#33 7 days ago
You definitely got me without that one
#34 7 days ago
Oops forgot to add the pictures
20190910_182702 (resized).jpg20190910_182727 (resized).jpg20190910_182807 (resized).jpg20190910_182812 (resized).jpg
#35 6 days ago
There is a relay that controls the pop bumpers.
YOU NEED TO LOOK AT THAT.
It is about the only thing you have not looked at.
#36 6 days ago
You won't find them online. Unlike every other manufacturer, Gottlieb claims copyright on their schematics. This means generally it's harder to get assistance with them because almost no one has documentation.
You can buy a copy from http://pbresource.com/mansch.html
#37 6 days ago
Did you report yet what happens when you turn the machine off when it is sticking?
#38 6 days ago
Yes it does unstick and go back to its original position
#39 6 days ago
OK thanks. As soon as I get it I'll get back to you
#40 6 days ago
OK, so that sounds electrical since as soon as you cut the power, it releases.
As for activating the flipper button and the pops releasing, the vibration from the flippers is probably enough to affect whichever switch/relay is still barely touching and keeping them energized. Like newmantjn said, look at the relay that controls the pop bumpers.
#41 6 days ago
Here is the pop bumper arrangement from Mibs, made just a few months before Road Race. It's the same basic arrangement for most games I suspect. Your wire colors will be different but the basic operation should be the same.
The two normally open spoon switches in the upper right corner are the spoon shaped switches just below the playfield on two different pop bumpers. When the ball tips the pop bumper skirt on either pop bumper the spoon switch closes and sends power to the pop bumper relay (the H relay in this game) which activates the pop bumper relay.
When the H/Pop Bumper relay activates it closes its own normally open lock in switch to keep itself active (or locked in) after the ball rolls away and the spoon switch opens.
At the same time the H/Pop Bumper relay closes two other switches that send power to the pop bumper solenoids. These switches will have larger, high current contacts on them so they'll look a little different than the lock in switch which will have smaller, lower current contacts.
With the H/Pop Bumper relay active and power going to the two pop bumpers, the pop bumper rings pull down and should eventually open the two EOS switches mounted below the spoon switches. Once both EOS switches open the lock in circuit is broken and power is cut to the H/Pop Bumper relay.
When the H/Pop Bumper relay relaxes the two switches sending power to the pop bumpers open to cut power to the pop bumpers.
It sounds as though your H relay switches (at the bottom of the schematic) aren't opening. So either the H/Pop Bumper relay isn't relaxing or the H relay switches are gapped too close.
The pop bumper relay is usually mounted under the playfield near the pop bumpers it controls. You should see it fire any time a pop bumper fires. Shut the power off and manually operate the pop bumpers and the pop bumper relay and see if every switch opens or closes as the device activates and relaxes.
#42 5 days ago
As MarkG has thoroughly explained, have a look at link to an animation I made a few years back. While the circuit wiring will differ to your title, same principles apply. Sometimes pictures can help.
#43 5 days ago
THIS.
#44 4 days ago
Quoted from MarkG:
The pop bumper relay is usually mounted under the playfield near the pop bumpers it controls. You should see it fire any time a pop bumper fires. Shut the power off and manually operate the pop bumpers and the pop bumper relay and see if every switch opens or closes as the device activates and relaxes.thank you so much for this I will get back to you with the results as soon as I get time to look. Thanks again
#45 4 days ago
Quoted from oldpins:
Thank you
#46 4 days ago
Quoted from MarkG:
Looks like I do not have an H relay however I do have ones on the underside of the Playfield as well on the bottom. The one's on the Playfield Underside are labeled sequence number one through 10
20190912_194938 (resized).jpg20190912_194956 (resized).jpg20190912_195021 (resized).jpg20190912_195038 (resized).jpg
#47 3 days ago
Quoted from MarkG:
I believe I found the relay. Letter C
#48 3 days ago
Quoted from MarkG:
Scratch that I've identified it elsewhere were I was never looking. It looks like none of the contacts are too close but I'm going to take a closer inspection
#49 3 days ago
Quoted from MarkG:
Okay here is a picture of it and it's opened state and closed meaning locked in and will not release without me Flipping The Flipper. What do you think?
#50 2 days ago
Quoted from MarkG:
One more thing when I turn off the machine the relay is still locked and the contacts are touching. I have to manually release the relay. Does this mean anything?
Metal-Mods
$ 11.95
$ 50.00
$ 7.95
Various Novelties
Pinball Wheezer
$ 119.95
Allteksystems
$ 99.00
Pinball Photos
$ 7,500.00
$ 269.00
CzTV Mods
$ 99.99
$ 9.99
$ 117.00
The MOD Couple
$ 999.00
$ 48.00
Metal-Mods
$ 1,099.00
$ 26.50
The MOD Couple
€ 9.95
Multigame
$ 69.99
$ 229.99
