Quoted from ritewhereiwant2b:Centerflank mentioned the magnet, it is a little bit raised. Has anyone lowered one? Does this effect gameplay? What is involved in lowering it?
I think it should be essentially just slightly above flush with the playfield.
If it is too high, it will cause the ball to both be nicked/pitted and bounce going into Doc Ock as well as mushrooming out the magnet core.
It's not that easy to lower or raise for that matter as they put thread lock on the nut. The magnet core has a screwdriver slot not a hex, so it is really difficult to break the thread lock loose.
But if you are lucky you can get the nut loose from the core and then adjust it.
The really f'd up thing (other than Stern using thread lock) is that the core has to thread out thru the playfield, but as you loosen the nut...it pulls the core into the playfield. So if the core is mushroomed, it can damage the playfield.
The whole thing would be much better if the core had a hex, so you could put a socket on the core and a wrench on the nut to break the nut loose.
On 2 machines with magnets, I had to physically cut the nut off with a Dremel type tool. I could get the core loose from the magnet housing, but couldn't get the nut loose from the core; as it is really difficult to get a grip on the core.
Remember, the core has to thread out thru the magnet housing and the playfield, so if you hose up the core threads, you can't get the core out of the machine if it's mushroomed.
Some people have luck heating the core and nut, I tried and finally decided it was faster and easier to cut the nut off.
Good luck.
Robert
