I hope someone will post the following onto the BKSOR thread. Thanks.
Hey Guys, I have some fixes for a couple problems you guys have mentioned on Pinside:
For JeffsPinballPalace:
Your Minion/Monster modes are set on difficult, and that's why you are frustrated! Go to game features adjustments. Adjustment #'s 21, 22, 23. 24, and 25 adjust the Worm, Hydra, Hell Hand, Magma Beast, and Lich Lords. Set them to Easy or Medium. I am not a good player and just completed 4 of them on Medium. There are not 3 levels to the modes. The modes are simple to achieve when set to factory Medium. Now we can calm down and enjoy some pinball!
To Anaraf, and anyone else who is having trouble shooting up the Flail lane to the upper playfield:
Power off. Take the glass off the playfield. Get a ball out of the trough. Level the Flail horizontally with your hand and rub the ball along both side walls and the floor *simultaneously* in the flail lane up and down from top to bottom. If you feel a click on the ball passing over one or more of the screws securing the flail lane floor, grab a #2 Phillips screwdriver and tighten them until you don't feel the click anymore. Screws sticking up too high will make it difficult to get the ball up to the upper playfield. The ball will slam into stuff on the the bottom of the upper playfield.
You could be having other problems with the flail lane, since you removed the upper playfield, which is no crime, but perhaps it didn't get fastened down correctly. Get a flashlight and see if you can see any obstruction in the ball's path up to the 180 degree scoop. You may have to take the playfield off again to see if wires or anything else are hanging down in the ball's path. Good luck!
Someone wrote that the Upper Playfield Cables running through the back panel don't all fit in the holes. Not true. If it were true, how did we ever build games and connect the connectors? The biggest connector goes in first, then the smaller cables on the left side. Form the wires coming out of the big connector to lay down parallel with the long edge of the connector a bit before you try this.
BKSOR definitely has flipper and other coil power adjustments! I suggest you use them before you alter your games.
Whip out your manuals and find all the adjustments you can make. There are more in BKSOR than ever before. Our engineers, Mark Guidarelli, Chuck Bleich, Tim Sexton and others have worked their butts off to advance our software and hardware. Put it to good use. Make your game fun for you, eliminate cranky posts, and enjoy your games as you like them.
Most of our games now have interlock switches on the coin door. When you open the door power is disconnected from the playfield. The interlock switch can be defeated for service by pulling it out (towards the coin door) a click. Voila! You can now enter diagnostics and make adjustments. Be careful.
Please read your manuals!
Steve Ritchie
