Quoted from Monster_Bash:Lets say we have a hard drive failure. The new Stern cost ya $5..the Woz cost ya $50. See I can pick the extreme end of the parts numbers too.
Shall I find the cheapest pinball MPU and the most expensive CPU\MB\Memory combo? I could..but I'm to lazy. There's are many sub $200 MPU replacement boards available.
It ten years (your timeline) are going to be able to get a new (again..you said brand new) compatible process for the current WoZ board? Probably not..so you're buying the board and at least the memory.
As a consumer in ten years (using your timeline again) how do I know what compatible board\CPU combo to buy when my Woz board blows up (you specifically said 'brand new motherboard') ? Will SATA controllers go away like IDE..what about a storage then? Will USB still be available on my 'new' board in ten years..or will it take the path of RS232 and PS2? And the most important...how to I port the software over to my new board? Does the WoZ OS magically have support board components that aren't released yet?
Sounds like a lot of work in ten years VS spending an hour and replacing a aftermarket MPU
I completely see what you mean about 'some people' having absolutely no clue about ISV solutions, infrastructure and road mapping.
Let me know when ya get past that 4th grade math..I'll give ya time to catch up
BTW If anyone wants to pay the Woz at the Strong Museum of Play..don't bother. While 30+ 30-35 year old arcade games and 12 or so pinball machines were all chugging along...this was the only machine that was down on Sunday20150103_131804.jpg 135 KB
in 10 years you will be able to buy a 100% compatible board/mem/cpu combo for WoZ. it was built MODULAR. It doesn't rely on some board house to create a CUSTOM part for a small niche market. Parts are readily available at any point. And even the current linux OS in 10 years will work as WoZ is 64bit compiled with abi compatibility enabled. Welcome to the world of STANDARDS. Using standards allows as much flexibility as you can imagine.
So yes in 10/20/30 years a standard Motherboard/CPU combo will absolutely function perfectly. It will also take less than 10 mins to swap. A few connectors and 4 screws and the board comes out easily replaced by a new one. Welcome to the world of proper design and enterprise engineering. Where people see the forest through the trees.
BTW
$50 dollars for a harddrive failure? Where are you buying your parts?
http://www.amazon.com/NexgenCover-128GB-Internal-Drive-Solid/dp/B00IXCFP9I/ref=sr_1_3
P.S. an SD card will fail with 10x the regularity of an SSD due to no wear leveling. So your $5 dollar SSD will actually cost you $50 over the same length of time a Single SSD would cost you at currently 1/4th the price. So you're analysis is completely wrong.
Nice try though.
