I have a Monopoly that has a sound issue. The callouts and sounds are fine but the music is barely audible. Suggestions on who is good with repairing these? Thanks
Check setting 43, "background music volume". Move towards 01 (loudest, and default on a factory reset).
Lower numbers are louder.
It's not that. I've gone through all the settings, tried a new rom, checked the speakers, voltages etc. I sent it off to be repaired and he thought he had it fixed but when I installed the board the music was still less volume than the callouts and before I could even play a game the music was reduced back to barely audible. I know I can send it I stern and may have to go that route.
The only other thing you might try out of desperation, is a full on factory reset of *all* settings. From my observations on other threads, occasionally a factory reset fixes "odd stuff" including sound. Stuff that you'd think would otherwise be fixed on a single setting basis. If you're about to send the board off, it might be worth the try. You'll of course lose the high scores in the process, but if you're sending the board off..
I am studying the schematic.... not the best at sound stuff, but i don't see a place where they mix two different analogue sound inputs like one is music one is effects.
There is a DAC that feeds a left and right channel. Two channels are mixed together for mono sound. Then there is a two 2030amps (push pull circuit???). I don't think this is going to be in the analogue / amplification side.
The digital side i have no idea how the XILINX sound chip works so i get stopped there. It is a 100 pin SMT, so not really easy to just swap in a new one.
Monopoly used the BSMT2000 (customized TI DSP) chip from the factory and not the XILINX processor. Of course finding a replacement to pop in there is nearly impossible.
The sound section on the WS board is the same as DE stereo sound. One of the things this means is that there is no validity checking on the ROMs:
https://pinside.com/pinball/forum/topic/help-request-vnd-voice-rom-2-sound#post-2525563
Could have another bad ROM or bad socket.
You can also swap CPU chips on the board and see if that has an effect.
Full reset is a good idea as well.
viperrwk
This page was printed from https://pinside.com/pinball/forum/topic/stern-whitestar-repair and we tried optimising it for printing. Some page elements may have been deliberately hidden.
