I am comparing my friends non-working Whitestar CPU-board and mine (working pcb). We both have LOTR. His is a LE, mine an original but both have same revision cpu pcb.
His is not booting at all. When you turn it on the GI lights come on but nothing more happens. We have tried swapping ram, rom and sound rom but no change. There is no acid damage.
When I move the pcb to the test bench mine has clock signal on test points E and Q. His pcb has no signal there, or anywhere else.
When I measure on crystal oscillator Y1 my working pcb has 3V on pin 1. His pcb has zero. If I interpret the Stern schematics correct it seems pin 1 is not connected and according to datasheet for the oscillator there is an internal 'pull-up resistor', thereby giving an active state.
This morning I tried to simulate a 'pull-up resistor' connecting a 100kohm resistor from 3,3V to pin 1 but there were not any clock signal anywhere... (I measured about 110kohm on my pcb, thereforte I tried 100 kohm...)
Does anyone have any info of how this crystal oscillator work?
Am I correct in suspecting his oscillator is broken?
Attached pic is from Stern schematics and datasheet.
Link to datasheet: https://www.mouser.se/datasheet/2/160/h5c2e-1166946.pdf
