(Topic ID: 324446)
Need advice- Stern code update download too big to copy to USB
By ctree5
5 months ago
  • 14 posts
  • 9 Pinsiders participating
  • Latest reply 5 months ago by flynnibus
    #1 5 months ago
    I downloaded the latest StarWars Pro update and plugged in a brand new SanDisk Ultra Flair USB 3.0 Flash Drive, 16GB, and ensured it was FAT-32 formatted . When I go to copy the downloaded file to the root directory, I get a windows message that the file is too large. Any advice? Thanks.
    #2 5 months ago
    Larger GB USB stick.
    #3 5 months ago
    Even if you copied the .zip file by mistake it's only slightly over 4 Gb so would easily fit on a 16Gb flash drive.
    Right-click on your flash drive. How much empty space does Windows say is available?
    What size are each of the .spk files after they have been extracted, before you try to move them to the flash drive?
    Double-check the file names. Sometimes the extraction program appends additional numbers (but that should not impact the size).
    #4 5 months ago
    I’ve had this happen before. I ended up reformatting the usb stick and it solved the issue.
    #5 5 months ago
    Quoted from YeOldPinPlayer:
    FAT 32 formatted drives have a file size limit of 4 Gb.
    #6 5 months ago
    Quoted from ctree5:
    . When I go to copy the downloaded file to the root directory, I get a windows message that the file is too large. Any advice? ...
    Quoted from Tuukka:
    Which is why you don't copy the dowloaded file to the usb, you unzip it there
    #7 5 months ago
    Quoted from Tuukka:
    2 Tb is the FAT32 drive size limit.
    The file size limit for any individual file is 4Gb. None of the files in question approach 4Gb.
    #8 5 months ago
    Quoted from ctree5:
    That's your problem - 'When I go to copy the downloaded file'
    When you download from Stern it will be a single zip file.
    Unzip that file on your computer and you will get multiple spk files.
    Copy THOSE files to the root level of your USB drive - not the zip file, not a folder of the extracted files.
    #9 5 months ago
    And indeed, the .zip file is 4.1 GB (as you say), which means it would not be able to be copied to a FAT32 drive.
    If the OP is incorrectly trying to copy the .zip file to the drive, that would explain the failure.
    They can instead open the .zip file from its download location on the PC, and just drag the files that are inside the .zip file over to the thumb drive.
    #10 5 months ago
    Quoted from pete_d:
    You caught me. I challenge you to a duel and insult your ancestry to the nth degree.
    #11 5 months ago
    Also don't have to unzip to PC first, straight to USB is fine.
    -3
    #12 5 months ago
    16GB USB drives were common 10 years ago. You need a bigger drive, 64GB minimum in 2022.
    #13 5 months ago
    Thanks all, unzipping and moving the individual files worked.
    #14 5 months ago
    Quoted from superNoid:
    actually the bigger drives have been problematic at times getting the devices to recognize them. Partitioning them to 8 or 16gigs is usually recommended to make them more reliable.
    This page was printed from https://pinside.com/pinball/forum/topic/stern-update-download-to-usb-fail and we tried optimising it for printing. Some page elements may have been deliberately hidden.
