Quoted from Hashman:Well that explains a lot. Will check the gap but obviously it is designed that way so it wasnt just my imagination. Never had a machine with different coils for each flipper (as far as I know). Thanks for your help. I do hit all those shots you mentioned, its just that its quite obviously weaker on purpose. Would like to be able to backhand the ramp but maybe putting in the same size coil as the right side may not be a good idea?
No matter what you do, you will not be finding the ramp a regular backhand shot. Maybe on a freak perfect shot you'll do it. But its not intended to be a backhand shot. You risk more of a reject to center drain than a success. Plus the game will become harder with the extra power to the close shots. Like missing the scoop and hitting the zuse standup at high power and air balling to the drain. There are other games with mis matched flipper coils. Iron man is another.
I would like to say that I have probably rebuilt over 100 flipper sets (100 full machines). And I use the flipper gap tool exclusively. I have had people asking me how I get my flippers to feel "better than new". I don't care how good you are, you should probably have and use the tool. I've even regapped flippers on NiB machines and improved their performance. I think stern eyeballs it in their factory Vid1900 wrote a rebuild guide on pinside and he even recommends the flipper gap tool.
Also, when you do a flipper rebuild, replace that nylon bushing between the flipper bracket and the playfield. That often is the cause of weak or loose flippers. You may not notice the difference until you replace it. It never comes with the rebuild kits but it sure makes a difference. http://www.pinballlife.com/index.php?p=product&id=271
