(Topic ID: 241383)
Stern Trident- Feature Lights Quit Working
By pindude80
5 years ago
  • 44 posts
  • 7 Pinsiders participating
  • Latest reply 5 years ago by pindude80
#1 5 years ago
I rebuilt the flippers on my Stern Trident this past weekend. I played a bunch of games right after and then a few later that evening. I went to play last night and after the first ball drained all of the feature lights went out. It did this to me once before and if I remember right I went to turn it on a few days later and they were working again. I checked all of the fuses and reset all board connectors but couldn't get them to come back on.
Can anyone tell me where and what I should look at first?
#2 5 years ago
Check voltage at the braid attached to all the lamps
#3 5 years ago
I checked it out at lunch. I took my DMM and put one lead on the braid and one on the socket lead where the wire is soldered and got no power whatsoever. I checked multiple lights with the same result.
#4 5 years ago
Put one lead on ground and one on the braid and you should get 5.4vdc. If not start tracing the connections from the braid back through the connectors to the rectifier board.
#5 5 years ago
I just checked the braid on the feature lights and I have 3.6vdc. While I was at it I also checked my GI and I have 3.6vdc there as well. I guess it's not a power issue. What should I check next?
#6 5 years ago
GI should be 6.3AC. Probably averages out to 3ish dc but not really applicable. 3.6vdc on controlled lights is definitely too low
#7 5 years ago
Ok, didn't know GI was ac. I guess 3.6 is too low for the control lights to even try to light because I have nothing at all, not even dim lights.
#8 5 years ago
I wanted to check TP1 on the rectifier board. I put the black lead on the ground braid and red on TP1 with the DMM set to DC and no reading. I then switched the black to a ground over by the service outlet on the wood panel and got negative 3.6 at TP1. Why am I getting a negative reading and no ground on the ground braid?
#9 5 years ago
Check both sides of fuse F1 - should be 7.8 VAC. If good there, check rectifier BR1.
#10 5 years ago
Quoted from pindude80:
Check on both sides of R2 on the rectifier board - can't get much closer to that as it's directly across the bridge that supplies the voltage to the feature lamps.
I think the bridge is bad though, sounds like a diode open to get the voltage you're seeing.
#11 5 years ago
I checked all of the rectifiers on the board and all tested good. One of the connectors was a little burnt so I went ahead and changed it out and my control lights came on. All of the lights worked except for one below the left spinner. I saw it was a red wire with a green stripe. I found a red with green wire on the lamp board, checked it, and wasn't getting continuity so I replaced the wire but the light wasn't coming on when it was supposed to; it is supposed to come on when you hit the top stand-up target but it was on without hitting anything. I got to looking at some of the other control lights and saw another one that wasn't working- the left most light for the stand-up targets that you knock down for the bonus multiplier and it turns out that light has the exact same red with green wire so I swapped my new wire to where the other red with green wire is and the light below the spinner that I put the new wire on lights properly now when I hit the upper stand-up target.
I started checking the other red with green wire and I was getting continuity from the connector to the wire on the lamp socket. I checked and I also am getting voltage but the light is not lighting up. I thought maybe something was wrong with the socket but I used a jumper wire from the lamp socket wire next to it and the light will light up nice and bright. There were a couple times that the problematic light would light up but it was dim and if I wiggled the bulb it would go out and not come back on until I re-booted the game and it didn't come back every time I re-booted the game. I pulled the light board and re-flowed that pin but it didn't change anything. I then did the test where you hook up to TP6 on the MPU and touch the wire for the light in question and the test led lit up which I believe verifies the scr, trace, and connection is good. I also stuffed a wire in the back of the connector, verified I had continuity and voltage on the added wire but the light still wouldn't light.
One thing that is also weird is once I was able to get my control lights back on after replacing the connector and crimp contacts was I was only getting something around 3volts at TP1 on the power driver board and on the control lights buss wire. After I replaced the wire for the first red with green wire I noticed my lights were brighter so I checked voltage at TP1 on the power driver board and the control lights buss wire and was getting a little over 5 volts.
Any ideas on what is going on or what I need to check next? Are the two red with green wires related even though they do different functions or is it coincidence and the factory just happened to use the same wire on two different control lights and that I had problems with both?
#12 5 years ago
So instead of keep chasing my tail I swapped the lamp driver board over from my Meteor, even though it's a Bally board, don't think that makes any difference and the light I was having problems with worked but a few others that were working weren't with the board out of my Meteor so either there are some problems on my Meteor board or it's not directly compatible since it's a Bally.
Is there anything I would want to look at on my original Trident board besides the SCR for the lamp that doesn't work?
#13 5 years ago
The connectors on lamp board may need soldering due to cold solder joints.
#14 5 years ago
Quoted from chad:
I agree. Re-solder the header pins. If that doesn't work, I would suspect a bad SCR for the lamps that are out. You can test these by grounding on TP3 and touching the top leg of the SCR. If it does not light, the SCR is faulty.
#15 5 years ago
I re-flowed the pin for the lamp I'm having trouble with and when I had the board out I verified I have continuity from the pin on the front side to the back side of the board and verified continuity from the backside of the board over to the SCR.
I'll try the test you mention, but let me make sure I have it right. I take a jumper wire and jump from the top leg of the SCR to TP3 on the lamp board and if the lamp on the playfield doesn't light the SCR is bad, is that right?
#16 5 years ago
Yes, that is correct. TP3 should be ground on the bally board. If you're working on the Stern board, it may be TP1, IIRC.
#17 5 years ago
Check this thread here for a Stern Stars that I was trouble shooting.
https://pinside.com/pinball/forum/topic/tilt-lamp-for-stern-stars
And for a Bally Paragon as well:
https://pinside.com/pinball/forum/topic/paragon-controlled-lamps-only-some-dont-work#post-4210142
You should be able to go through similar troubleshooting steps.
#18 5 years ago
Cool, thanks for letting me know about the test and verifying! I think you are correct about TP1 being ground on the Stern board; I figured that out when I was trying to test board voltages and I was told to check TP1 for 5vdc and I didn't come up with anything. I'll give the test a try and post up my results.
#19 5 years ago
All lamp boards should be compatible fyi
#20 5 years ago
Quoted from zacaj:
Ok, I thought so but wasn't 100% sure. I guess the ground TP is different between Bally and Stern though?
#21 5 years ago
The parts and components can sometimes be numbered different but any lamp board should work in any game
#22 5 years ago
That's about the only difference - TP1 and TP2 are reversed between Bally and Stern Lamp Driver Boards.
Bally has TP2 as GND and TP1 as +5 volts DC.
Stern has TP1 as GND and TP2 as +5 volts DC.
TP3 on both mfg boards is a test voltage used for manually switching on SCRs for diagnosis.
#23 5 years ago
I did some testing. Ground to the top Center leg of the scr didn't do anything. When I went from test point three, 5vdc, to the bottom right leg on the scr the light lit. Does that mean the scr is bad?
#24 5 years ago
Yes. Here is the explanation from Quench
https://pinside.com/pinball/forum/topic/paragon-controlled-lamps-only-some-dont-work#post-4210216
It's from the same thread. If you haven't read through the entire thread, it is well worth the read as he basically runs me through lamp troubleshooting step-by-step and we also discover that my rectifier board is going bad. I learned a LOT from this experience!
#25 5 years ago
I did read through the entire thread, some parts more than once. He says: "The top (middle) leg of the small SCRs is the "Gate" leg - you can see next to Q4 it is marked "G". Connecting TP3 on the lamp board to the gate leg manually switches on the SCR. If the respective lamp doesn't light, the SCR is suspect." This not what I did, I went from TP3 to bottom right, guess I should have went to the top leg? I went from top leg to ground which didn't do anything. I'm wondering what I did, TP3 to bottom right does, I'm guessing bypasses the SCR and powers on the light?
#26 5 years ago
You'll want to test the bottom right leg on TP2, which is grounding the lamp socket. This is testing the wiring on from the board to the lamp socket. If it lights, your wiring is good. If you take TP3 and touch the top leg, you're testing the SCR. If you touch these 2 points, and it doesn't work, then your SCR is bad.
#27 5 years ago
If the respective lamp lights when you connect the lamp driver board test point TP3 to the gate leg of the SCR, then the SCR is likely good. When you grounded the metal tab of the SCR and the lamp didn't light, it was more likely a bad connection with your jumper lead - it should have worked seeing as TP3 to the gate leg worked.
Which lamp driver board and SCR(s) are you concentrating on at the moment?
According to the lamp schematics with reference to the two red-green wires:
Lamp board Connector J1 pin 3 (red-green) wire goes to the left spinner white lamp.
Lamp board Connector J3 pin 3 (red-green) wire goes to drop target #1 lamp.
Note with the lamp driver board, the connectors start with pin 1 at the bottom and count upwards - the other boards in the game start with pin 1 at the top and count downwards.
#28 5 years ago
Quoted from FatPanda:
TP1 is ground since I'm working on a Stern board but last night I tested ground to the top leg per what we were talking about earlier. I will have to try TP3 to the top leg and see what happens.
#29 5 years ago
Quoted from Quench:
Is the gate leg the bottom right leg when it's mounted on the board? The bottom right to TP3 is what made the light come on.
Quoted from Quench:
My game has a Stern lamp board in it, LDA100. I am trying to fix J3 pin 3 for the drop target # 1 lamp. I did see and made reference that the pin number one is at the bottom and go up from there. I've been testing Q60 which I believe is the correct SCR for J3 pin 3
#30 5 years ago
There's three versions of LDA100 lamp boards. Rev A (blue colored) and rev B and C (green and skin colored respectively). Rev A has the SCRs layed out in different orientation compared to rev B and rev C.
Stern Rev A:
* small 2N5060 SCRs;
---- Cathode = bottom left
---- Gate = top
---- Anode = bottom right
* larger MCR106 SCRs;
---- Cathode = top
---- Gate = bottom
---- Anode = middle
Stern rev B and rev C:
---- Gate = middle
---- Anode = top
---- Gate = top
---- Anode = middle
Yep, SCR Q60 goes to J3 pin 3 according to the schematics. It's one of the smaller 2N5060 SCRs.
#31 5 years ago
I would like to double check which one it is but I'm almost positive it's Rev A because it's a bluish color. If it's Rev A, which I think it is, what test do I need to do to see if the SCR is bad? I went from TP3 to bottom right and the light lit.
#32 5 years ago
This should not work at Q60 on a rev A board.
Please post a picture of the lamp board and the SCR in question.
#33 5 years ago
Ok, I'll try and grab a picture of it at lunch.
#34 5 years ago
Pictures of the board, Q60, and a label on the board.
IMG_20190507_141355 (resized).jpgIMG_20190507_141355 (resized).jpgIMG_20190507_141406 (resized).jpgIMG_20190507_141406 (resized).jpgIMG_20190507_141418 (resized).jpgIMG_20190507_141418 (resized).jpg
#35 5 years ago
The letter "A" under "LDA" on the label says it's a rev A board.
When you ground the bottom right leg of SCR Q60, the lamp should light. All this will tell you is that there's connectivity from Q60 to the lamp socket.
When you connect TP3 on the lamp driver board to the top leg of SCR Q60 the lamp should light. This manually activates the SCR and tells you whether Q60 is working or not.
#36 5 years ago
Quoted from Quench:
Ok, I was pretty sure it was a revision A from your description above but thanks for confirming. I was thinking that you would say TP3 to the top leg of Q60 would manually activate the SCR so I will have to check this and report back.
#37 5 years ago
I know you're troubleshooting the lamp board but it appears that the MPU was repaired from battery corrosion at some point. I would highly recommend that the battery is removed and NVRAM is installed. They can be had for <$20 shipped and well worth it. With quench on the case, he'll have you up and running in no time!
#38 5 years ago
Quoted from FatPanda:I know you're troubleshooting the lamp board but it appears that the MPU was repaired from battery corrosion at some point. I would highly recommend that the battery is removed and NVRAM is installed. They can be had for &lt;$20 shipped and well worth it. With quench on the case, he'll have you up and running in no time!
Yeah, I know this is something I should look into and it bothers me seeing the battery on the board like that.
#39 5 years ago
Quoted from Quench:
I ran a jumper wire from TP3 to the top leg of Q60 and as we suspected the light did not light and the SCR is bad.
#40 5 years ago
What about running a jumper wire from ground to the bottom right leg of Q60?
If the lamp lights, then yes Q60 is suspect.
If it doesn't light then there's a connectivity issue from the bottom right leg of Q60 to the lamp itself, or there's an issue with the lamp/socket.
#41 5 years ago
Quoted from Quench:
Yes, it lit running a jumper from ground to the bottom right leg.
#42 5 years ago
Just wanted to let you guys know I bought a soldering / de-soldering station, replaced my first board component, which was this SCR and now the light that didn't work is fixed! My friend came over and gave me a good tutorial on soldering / de-soldering on board work and he also brought his Pinitech control lamp tester that was referenced earlier in this thread; that thing is awesome!! We checked my EBD and Meteor, found a few SCRs that need replaced so more solder work for my new tool!
Thanks to everyone for the replies, info, and helping me get that one pesky light going that was driving me crazy!
#43 5 years ago
Thanks for following up and great to hear it's resolved! You might get dangerous with that new desoldering station
#44 5 years ago
Quoted from Quench:
No problem! I try to follow-up on all of my threads that get resolved in case someone stumbles upon it in the future or I might even be the one to need it a few years later and forgot what I did to diagnose and fix the problem. Big thanks again to the contributors that provided info.
I know, I feel I could be dangerous with it also! I'm glad I bought it, especially since I have quite a few older games, I feel at this point it's a mandatory tool for the size and current games in my collection.
$ 5.95
The Pinball Scientist
$ 29.00
RoyGBev Pinball
$ 29.00
RoyGBev Pinball
Troxel Repair
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 69.00
$ 169.00
Cabinet Parts
$ 3.00
Cabinet Parts
20eyes
