I'm still not understanding why you're not getting a pulse on pin 9 -- seems like you've eliminated all the possible causes.
Regardless, it really looks like your U6 is doing the right thing now.
When U6:Pin 6 is high, it basically turns Q6 into a short, which mutes the LM380s.
Then, after the 7th flash, when U6:Pin 6 goes low, Q6 doesn't short the bypass of the 380s, so you should get sound.
Like you said earlier, when you have 0 voltes to pin 1 of U20 and U21, you have no sound. 8 volts and it works.
I know you've replaced Q6 already, but I'm wondering if you would consider running an experiment. The top leg of Q6 (blue arrow in this picture)
Is the final stop in the chain of components that bypasses the LM380s. If you could pull just that one leg (the top one), the machine should start making noise as soon as you turn on power. Basically, there would be nothing telling the amps to stay quiet until everything is booted.
If pulling that leg reliably gets you sound, and U6:pin 6 goes from high to low after the 7th flash, then the only problem could be R67, R68, or Q6.
Normally, these cards are not nearly this difficult to diagnose!
I had one catch on fire and it was easier to fix than yours.
