(Topic ID: 288529)
Stern TMNT sword shooter rod issue
By Kneeno
9 months ago
  • 8 posts
  • 7 Pinsiders participating
  • Latest reply 64 days ago by Pinballmonkey
#1 9 months ago
Installed the Stern Leonardo shooter rod on my LE and when manually plunged all the way back the ball won’t even make it onto the playfield, until it’s auto plunged. The shooter rod tip is back further on this plunger than any of my other games. The rod/spring is the exact same as the one it came stock with, as I even tried swapping them with the same result. It comes with the “red” spring which looks to be the strongest. I thought about shortening the spring by the sword handle to make up some of the gap. I read about “stuffing” the rubber shooter tip add length. Any other thoughts?
071C3E86-5CF6-44D0-9F22-29772BA881CA (resized).jpeg8C78EAB8-4C25-4A5D-94BF-3AD4385090F1 (resized).jpeg
2 months later
#2 6 months ago
Hey mate I just got mine having the same issues, did you end up being able to solve the issue?
#3 6 months ago
It comes stock with an orange spring, it kind of looks red. I had the same issue and swapped the orange with a purple spring and it works much better. This one, https://www.pinballlife.com/ball-shooter-plunger-inner-spring-purple.html
3 months later
#4 3 months ago
Fools dont even test their own products, sad!! Yes the stock spring is too weak, needs the red spring. I had same issue
3 weeks later
#5 74 days ago
Quoted from MJK-911:
Red spring from pinball life worked for you? I'm having the same issue. Tried both springs to no avail.
#6 74 days ago
Just my opinion. The sword shooter rod feels cheap and doesn't work well. I've had it on mine for almost a year now and I am goin back to the stock rod.
#7 69 days ago
I reached out to Stern and they instructed me to remove the washer on the katana side. It helped a lite, but it's still weaker.
#8 64 days ago
Replace the shooter spring with the red version
That fixed my issue
