Hello All,
I have a switch on my Stern Austin Powers which is not registering on the switch test. The switch in question is # 38, which is the right roll under switch (right ramp exit).
As mentioned, I cannot get this switch to register on the switch test. Now I can get switch # 34 to register and this is in the same column as my non-registering switch. I can also get switch # 6 (left coin slot) to register which is in the same row.
I disconnected the switch (#38) where it plugs into the wiring under the playfield and shorted the two connector pins out and still no confirmation of a switch closure being seen by the CPU.
This is where I need to have some help fro those far more skilled at this than I.
Appreciate all assistance. Thank you
George...
