Hi Pin people!
recently finished cleaning new pin. Making sure that everything is fine. Finally got the balls to start it up with no fuse blowing on the rectifer board.(all fuse are checked and ok) Checked all test point and header pins voltages with sucess reading: TP1 6.13vdc, TP2 251vdc, TP3 11.7vdc, TP4 6.8ac and TP5 44.6vdc. Also took the same reading straight on the 12 VDC orange wire itslelf on J3 rectifier board.
Then plugged all header pins onto SDB trying to see if voltage is good with no luck.
J3 pin 12 (orange WIRE) and TP2 on SDB read low voltage 1.3 and are suppose to be 12vdc.
SDB MODEL: AS-2518-22
The capacitor on SDB are new. No fuse are blowing. Playfield and backglass light are ok. No digit on displays. No coil trigering on start. Connectors looks fine and pins are fine...
PLEASE HELP!
