Hi all... would appreciate some tech help here with my Stars. Bought it a couple weeks ago and it wasn't working.
(Apologize for any wrong terminology, I'm pretty green when it comes to electronics work)
When I go it I noticed right away there was a jumper wire soldered from the ground post on the out hole coil to the ground post on the left drop target coil. Then another jumper from that post to the ground post on the right drop target coil.
I removed the obvious hack in the outhole to drop target wire, replaced the fuses and gave it a try. The game fired up but the outhole coil wasn't working.
So out of curiousity I tacked the hack wire back on and everything worked as it should. (Display is a little flickery) but game play appeared to be good. This worked for a couple days then it quit booting up. (Was only getting 5 out of 7 lights on the boot up sequence).
Some investigating revealed that the coil fuse was blowing on the bridge rectifier instantly on power up. So I assumed it was connected to these goofy hack. So I removed both... the outhole to drop target and the drop target to drop target wire. I then traced the ground wires for all 3 coils back to the power supply. I check continuity in all 3 wires and the wires appear to be good all the way from coil to power supply.
The two drop target ground wires go to the J5 plug on the power supply while the outhole ground goes to the J1 plug on the power supply.
Anyway... after removing the hacks I replaced ALL fuses with the proper sizes just to start fresh and booted it up. Everything boots properly.
BUT... the outhole coil is still dead. And the RIGHT drop target coil is stuck energized. Not 100% sure if the LEFT drop target coil is working at all as I powered down right away.
Little unsure where to go from here but here's a couple other things to note:
On the Power supply there is a diode (CR3) and a resistor (R16) that appear to be missing. Not sure why those have been clipped out. Could that be for a reason or should those be replaced before I go any further?
I'm guessing there are some transistors blown but I'm not really sure how to test them.
Included a power supply pic for reference.
Appreciate any help.
Some other little things... My chimes are missing a lot of spaces. Various things have been improvised but they don't sound great. Where can I find replacement spacers. Also need a pop bumper cap. (Assembly has a loose bulb socket too... pretty flickery). Also have a broken white "Stern" plastic in the top left orbit.Photo on 14-04-05 at 9.02 AM.jpg
